Home Electrical Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 07:10 AM   #1
Some electrical outlets and lights are not working. Can some one tell me what to do?
Mammo is offline   Reply With Quote
Old 07-12-2011, 07:13 AM   #2
Rewards Points: 1,668
most common cause is a loose connection either at the outlets, switches, in a junction box, or in the electrical panel. Are those that don't work on the same circuit breaker or fuse?
bob22 is offline   Reply With Quote
Old 07-12-2011, 07:24 AM   #3
It was working suddenly part of the house outlets and lights stopped working. I looked in the panel all are on the on position? Where else can I look at to fix this problem?
Old 07-12-2011, 08:36 AM   #4
Just call me Andrew
Rewards Points: 1,020
You need to answer this question...
Andrew
secutanudu is offline   Reply With Quote
Old 07-12-2011, 08:51 AM   #5
It looks like it. They all went out at the same time.
Old 07-12-2011, 11:03 AM   #6
Learning by Doing
Leah Frances's Avatar
This is not proof they are on the same circuit.
We need some more info to really help.
Do you have a circuit map? Any chance of a MWBC? have you flipped the culprit 'circuit' off then back on? What precipitated the power loss? Storm? Plugging in new item? Anything?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-12-2011, 11:52 AM   #7
Rewards Points: 120
A tripped circuit breaker does not always appear as such. One by one, go down each side of the panel, switching off, then stwitching back on, each breaker.
Electrical wiring exposed....problem or not?? pipsal Electrical 4 03-22-2010 11:49 AM
electrical requirements for large whole home system jumonji Electrical 6 02-23-2010 01:41 AM
Home Electrical Problem jogan Electrical 10 07-27-2009 08:57 PM
Home electrical advice needed jiminy Electrical 11 12-14-2007 03:13 PM
