Old 11-08-2011, 07:03 AM   #1
Home Electrical Panel Main
The electrical panel in my house does not have a main breaker installed in it. My house is only 5 years old and some how passed the local county code as well as a home inspector I hired. My question is it common to not have one in the panel and is that something I could do myself. I am pretty competent with electrical work. Thanks.
thornton0715 is offline   Reply With Quote
Old 11-08-2011, 07:12 AM   #2
I have heard of areas that do not require a main breaker, mind boggling!!! Others may chime in, but I see the best fix(not least expensive) as replacing the panel.
Old 11-08-2011, 07:13 AM   #3
Electrical Contractor
Do you have a main disconnect outside near the meter?
If you do, you are good to go.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 11-08-2011, 07:15 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
I guarantee you have a main breaker somewhere.
Old 11-08-2011, 09:47 AM   #5
kbsparky's Avatar
You do not need a main breaker in your load center if there is a service disconnecting means at your premises.
Look at the meter: Is there a combination box with a breaker in it, or separate disconnect enclosure adjacent to the meter?
-KB
Old 11-08-2011, 09:59 AM   #6
This is what I have. I don't know the exact code requirement as I'm not a pro, but I think a disconnect at the meter is required if the cable from the meter to your load center is over a certain length.
wiring sub panel right next to main panel bill423 Electrical 4 05-14-2011 09:17 PM
Maxed out main panel and sub panel - additional 240v needed netcustoms Electrical 4 03-12-2011 12:40 PM
Multiple Panel Question theatretch85 Electrical 5 12-12-2009 06:26 AM
Subpanel for now, convert to 2nd main panel later? abmiller67 Electrical 2 08-27-2009 02:44 PM
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 05:52 PM
