-   -   Home Electrical Panel Main (http://www.diychatroom.com/f18/home-electrical-panel-main-122760/)
thornton0715 11-08-2011 07:03 AM
The electrical panel in my house does not have a main breaker installed in it. My house is only 5 years old and some how passed the local county code as well as a home inspector I hired. My question is it common to not have one in the panel and is that something I could do myself. I am pretty competent with electrical work. Thanks.
Just Bill 11-08-2011 07:12 AM
I have heard of areas that do not require a main breaker, mind boggling!!! Others may chime in, but I see the best fix(not least expensive) as replacing the panel.
jbfan 11-08-2011 07:13 AM
Do you have a main disconnect outside near the meter?
If you do, you are good to go.
Speedy Petey 11-08-2011 07:15 AM
I guarantee you have a main breaker somewhere.
kbsparky 11-08-2011 09:47 AM
You do not need a main breaker in your load center if there is a service disconnecting means at your premises.
Look at the meter: Is there a combination box with a breaker in it, or separate disconnect enclosure adjacent to the meter?
md2lgyk 11-08-2011 09:59 AM
This is what I have. I don't know the exact code requirement as I'm not a pro, but I think a disconnect at the meter is required if the cable from the meter to your load center is over a certain length.
