At Home 30A RV Hook Up - Electrical - DIY Chatroom Home Improvement Forum
Old 05-14-2013, 09:50 PM   #1
At home 30A RV hook up
is there a diffrence between wiring up a 30A plug outside right off the breaker panel for a RV hook up vs. say for a home dryer?
Exjay is offline   Reply With Quote
Old 05-14-2013, 09:55 PM   #2
Licensed electrician
Rewards Points: 1,278
The dryer is 240 volt and either 3 or 4 wires depending on its age.
The RV will be 120 volts with one hot, a neutral and a ground.
Old 05-14-2013, 09:59 PM   #3
MarginallyQualified
Rewards Points: 2,464
Is your RV a 240Volt connection like a dryer?
Take a look at your cord.
Link
Old 05-15-2013, 06:34 AM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
30A RV and travel trailer circuits are 120V 3-wire.
50A circuits are 120/240V 4-wire.
The Following User Says Thank You to Speedy Petey For This Useful Post:
Philly Master (05-15-2013)
Old 05-15-2013, 07:34 AM   #5
Rewards Points: 3,130
Yes, there is quite a difference. RVs with 30-amp electrical have a 3-prong plug that is not used anywhere else in the U.S. The easiest way to accomplish what you want is to go to an RV parts place and buy a panel that's equipped with the necessary receptacle (a TT-30R). Mine cost about $40. You'll also need a 30-amp single pole breaker, which any big box store should have. The wiring is essentially the same as any other 120vac receptacle (hot, neutral, and ground).
Unless you need to run the air conditioner, an easier solution is to buy an adapter and a 12-gauge extension cord and just plug into one of your existing outside receptacles.
Old 05-15-2013, 03:06 PM   #6
Thanks guys. no, our camper is 120 30A not sure why i was thinking 240 dryer . Anyways, we have the 120 outlet adapter but on occasion it trips the outside GFCI due to the load. I would like to beable to run things for a few days (inc the AC unit and fridge) a few days before our trips out just to make sure all is good. also it convient that out camper is parked on the side of the house right next to the breaker panel which will minimize our wire run.
Old 05-15-2013, 03:09 PM   #7
The GFI is not tripping due to the load. It is sensing a fault that current is leaking somewhere and shutting off. Breakers trip due to overloads.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
mpoulton (05-15-2013), tylernt (05-15-2013)
Old 05-15-2013, 05:13 PM   #8
Semi-Pro Electro-Geek
Rewards Points: 2,902
If the GFCI is tripping, it indicates a ground fault in your trailer. This is a safety hazard and needs to be fixed. GFCIs do not trip from overloads, only from ground faults.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 05-15-2013, 05:41 PM   #9
Rewards Points: 150
It may not be an issue with the RV but could be as simple as a worn cord.
usair is offline   Reply With Quote
Old 05-15-2013, 05:56 PM   #10
The reason you were thinking "dryer" is because up until 1996 the NEMA 10-30 receptacle could be used for dryers. The NEMA 10-30 is ungrounded 240/120VAC, but it looks A LOT like a NEMA TT-30 which is grounded 120VAC. THEY ARE NOT THE SAME! Since it was acceptable up to 1996, there is a high potential to find NEMA 10-30 in a home laundry room or garage.
There have been plenty of cases where people thought this dryer receptacle was the same as their RV plug since they look very similar, forced the plug and ZAP killed the electrical in the RV. (Go to RV.net and do a search, it is not uncommon) Sometimes even the pro's mess it up. There was a thread recently where an RVer paid a pro to install and wire a 30A 120VAC for their RV. The pro installed the proper NEMA TT-30, but wired it as 240VAC. ZAP!
FixitDragon is offline   Reply With Quote
Old 05-16-2013, 07:19 AM   #11
^ Just got done working on my dryer a week ago and maybe thats why I was thinking that. The GFCI outlet is used alot outside from x-mas lights, yard tools, battery chargers, etc and maybe a bit worn. the GFCI trips on occasion and not specifically related to my RV but sometimes on the above things also. I will start there with replacing the outlet to fix this issue but I did find a good yourube vid for properly wiring a at home RV outlet. Once I get this done I will post up some pics of my install.
Old 05-16-2013, 05:08 PM   #12
Rewards Points: 31
Can you post the youtube link? I am curious
Olsy is offline   Reply With Quote
Old 05-16-2013, 07:35 PM   #13
Rewards Points: 484
My GFCI used to trip with our RV at home but only because I would try to run the air and the circuit just wasnt large enough.
I ended up doing like suggested earlier. I Went to Lowes and bought a 30 amp single pole breaker, 10 gauge wire and they had had a female RV receptacle, they call it a trailer plug.
sammy37 is offline   Reply With Quote
Old 05-16-2013, 07:41 PM   #14
GFCI's do not trip from overloads. That's not what they do or how they work. If the GFCI trips, it is because current is leaving the GFCI on the hot wire but not all of it is returning through the neutral wire. The only thing the GFCI senses is this imbalance, not the total current flowing through it. If your GFCI tripped when the AC came on, it's because the AC had a ground fault.
Old 05-16-2013, 11:26 PM   #15
Rewards Points: 484
You are correct. Now that I think back, I had to reset the breaker not the actual GFCI outlet itself.
Old age is starting to get me!
1938 TN Home - My First Home, My First project, Tons of Pictures!!! Firefighter3244 Project Showcase 78 07-01-2014 11:55 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Condensation amyevans Windows and Doors 6 10-21-2011 11:11 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
