Hole Locations In Metal Electrical Boxes - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2013, 01:59 PM   #1
Rewards Points: 1,628
Hole locations in metal electrical boxes
If you take a standard 4" square electrical box, one say 1-1/2" deep and another 2-1/2" and put them together flushed on the faces. Why are the knock out holes for each not aligned depth wise?
Seems most times you would want to mount them with the face flushed with the studs and if you did you can't connect these boxes to each other with a straight conduit because the holes are set at different depths.
Just curious why they designed it that way.
miamicuse is offline   Reply With Quote
Old 08-18-2013, 02:55 PM   #2
Rewards Points: 4,796
I woudn't say those boxes (meaning "handy" box style) are most often installed flush with studs. More often I've seen them in places where the bottoms are aligned with each other, not the tops. Unless you mean a dougle gang box intended for switches and outlets, then yes I'd expect them to be face flush.
jeffnc is offline   Reply With Quote
Grounding Metal Boxes and Outlets - Confused by Something Simple ALFisher Electrical 42 04-28-2015 12:14 PM
Protectors for electrical boxes from sheet rockers miamicuse Electrical 9 05-26-2012 07:56 PM
grounding metal boxes bkvanbek Electrical 1 06-28-2011 06:08 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Electrical boxes in attic Cossack Electrical 6 02-27-2008 02:08 PM
