Hole For Box Cut Too Big... - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 01:31 PM   #1
Rewards Points: 83
Hole for box cut too big...
I have a few places where the drywall guys cut the hole for the receptacle boxes too big for the ears to rest on the wall. Any tips on how to shim or otherwise remedy this so the receptacle has a firm base to rest against?
Bubbagump is offline   Reply With Quote
Old 10-28-2008, 02:09 PM   #2
Res Ipsa Loquitur
If it is a small amount like 1/8", there are spacers that can fit under the mounting screws (GB & Ideal makes them, my Lowes shows them as bright green) for just that purpose sold in home stores and electrical supplies.
You won't be depending on the ears for support, just the mounting screws.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Old 10-28-2008, 02:20 PM   #3
Anything sized properly to slip over the mounting screws and fill the space between the recep and the box.
Sometimes a couple of nuts slipped over the screw will do the trick. Sometimes a crimp sleeve or two. Got some 1/4' coper tubing??
You can strip some insulation from #8 wire but it will squish a little bit.
Use you imagination. Nylon cover plates help too. You can tighten them down good and they will not crack.
220/221 is offline   Reply With Quote
Old 10-28-2008, 03:40 PM   #4
Electrician
Thats actually a code violation to have a gap bigger than an 1/8th, so I would have the tapers fix that.
chris75 is offline   Reply With Quote
Old 10-28-2008, 04:36 PM   #5
Rewards Points: 1,910
Yes, have the drywall guys fix their shoddy work.
Old 10-28-2008, 07:59 PM   #6
dSilanskas's Avatar
A plastic box extension is the best way to go if you want it done the right way.
dSilanskas is offline   Reply With Quote
Old 10-28-2008, 08:46 PM   #7
Electrician
No, fixing the drywall is the best way to go.
Old 10-29-2008, 07:15 AM   #8
dSilanskas's Avatar
Okay let me re word that. The easiest fastest way to go
Old 10-29-2008, 03:39 PM   #9
Electrician
just checking.
Old 10-29-2008, 03:51 PM   #10
The box extension I am thinking of would still not solve the problem as they don't extend out farther than the ears.
Unless you stand thare and tell him to fill the gap with filling compound, the drywall guy is only going to flat tape the box and the recep will still not have any support. Then you have to repaint eyc.
"Best" is a relative term. Shim it, cover it, learn from your mistake and move on.
Old 10-29-2008, 03:59 PM   #11
Electrician
Ever use these?
http://homefixated.com/archives/2008...spector-happy/
Old 10-29-2008, 08:09 PM   #12
dSilanskas's Avatar
Thats the one I was saying to use plastic box extension
Old 10-29-2008, 08:20 PM   #13
Electrician
I kinda figured since i've used pleanty myself, and they do a pretty good job of filling in the gaps.
Old 10-30-2008, 12:20 AM   #14
That's what I was thinking of.
The top/bottom are no longer than the ears on the recep so they wouldn't help hold the recep in place.
Unless I'm missing something????
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 09:35 AM
Larger hole in foundation jamiedolan Building & Construction 5 10-02-2008 11:04 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 10:28 AM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 08:08 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
