#16 |
Electrical Contractor
Ho water heater wiring
In this case yes.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
| The Following User Says Thank You to jbfan For This Useful Post: | Savinmoney (09-25-2012) |
#17 |
Since you have no power at all, get yourself a "tic tracer" It's a tracer commonly used by telecommunications people for tracing wires. You can use it to trace every circuit and outlet as long as ther is no power to them. It's battery operated and sends a tone over the wires. Then you have the receiver which allows you to find the tone therby locating it. $30-$100.
Do you want it your way or the right way? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to Missouri Bound For This Useful Post: | Savinmoney (09-26-2012) |
#18 |
Licensed Electrical Cont.
NO! An older dryer circuit would be either SEU cable, or black, white and red with no ground.
If you have a dryer with black, white and ground, it was NEVER legal or correct.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
| The Following 2 Users Say Thank You to Speedy Petey For This Useful Post: | HouseHelper (09-26-2012), Savinmoney (09-26-2012) |
#19 |
An old Tradesmen
Threads merged. makes it easier for members to answer your questions better.
| The Following 2 Users Say Thank You to beenthere For This Useful Post: | jbfan (09-26-2012), Savinmoney (09-26-2012) |
#20 | |
Ho water heater wiringQuote:
#21 |
tempo progressive 200HP inductive amplifier / 77HP tracer-2 toner tone & probe
I've got one of these.
| Display Modes | |
| rumbling pipes and leaking pressure relief valve | rogerwright | Plumbing | 21 | 04-14-2012 03:35 PM |
| elevate electric water heater? | crankbait09 | Plumbing | 18 | 04-18-2011 12:35 PM |
| Pressure drop across water heater, low hot water flow | HVAC_NW | Plumbing | 2 | 01-17-2011 11:43 PM |
| Solar hot water | indatom123 | Green Home Improvement | 0 | 12-19-2010 01:01 AM |
| Bosch 1600H Tankless Water Heater | natemclain | HVAC | 13 | 08-24-2009 11:33 AM |
