Hight Of Romex Off Floor - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2010, 11:39 AM   #1
Rewards Points: 150
hight of romex off floor
when I'm running romex through studs between general purpose receptacles, is there a minimun height above the floor it needs to be?
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 08-22-2010, 11:49 AM   #2
No specific height required
I usually like it at least 5" off the bottom plate in case there is any chance a nail can be driven up thru the plate
Also above the area where any base trim might be on the wall
Another place a nail can go into the cable
Other then that I drill holes & run it either above the boxes or below
Usually above the boxes is easier when wiring - for me
Old 08-22-2010, 02:46 PM   #3
Rewards Points: 835
i wouldn't come close to top or bottom plates. i run all my wires at 18" above floor. usually no window (or other) interference, i always know where they're at, and convenient heighth to drop into receptacle boxes.
TimPa is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 10:23 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
Help wih floor extremer1519 Flooring 1 12-27-2005 06:33 PM
