High Voltage Test ?? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-19-2009, 10:17 AM   #16
Rewards Points: 1,002
Who told you any of this? You have several obvious professionals from contractortalk telling you this is BS. When ever you are told something, find out who is doing the telling. I can't tell you how many jobs I've done where the owner comes up and says "someone said", and you figure out that someone has the professional construction credentials of a poodle.
Anti-wingnut is offline   Reply With Quote
Old 10-19-2009, 12:04 PM   #17
Rewards Points: 82
This is absolutely true. Whomever told you this is full of you know what. An Electrical inspector will never take any wires loose or use any kind of measuring device with the exception of the simple polarity tester you plug into an outlet.
Also, there is no such thing as "high voltage" in a residence.
Ant-wingnut, Theres got to be a reason for your forum name?
Old 10-19-2009, 05:58 PM   #18
Very interesting. Thanks again. I'll be speaking to this person hopefully soon. Then I'll post the updates.
Melanie337 is offline   Reply With Quote
Old 10-19-2009, 07:02 PM   #19
Advice worth 2 cents!
Rewards Points: 150
Go Melanie!
I'm dying to know what this is all about!
_Peter
---pete
HandyPete is offline   Reply With Quote
Old 10-19-2009, 07:20 PM   #20
Unless your husband convinced you to run the place on a 4160V genset with 13,800V transmission to run 600V (480V in the US) shop equipment and all the necessary switchgear you would never need to high-Pot (high potential over-voltage test, or "megger" short for Megaohmeter, a device used for the test) anything in a residential application. As the others mention inspectors will not pull anything apart, just test your polarity, ground and ground fault interrupt.
Find out who the BS'er is and take em to task!
Salem747 is offline   Reply With Quote
Old 10-20-2009, 03:19 PM   #21
Rewards Points: 82
Hey, I like you. Right to the point.
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
wiring Dual voltage motors tiquilagold Electrical 12 07-13-2009 11:24 PM
Negotiating w/Roofer - High Price - need advice Dodah Roofing/Siding 11 06-23-2009 08:31 PM
2 - 900w tansformers on a 15A circuit? tonyBagadonuts Electrical 19 07-20-2008 08:15 PM
Old refrigerator = high power consumption? RammsteinNicCage Appliances 6 06-13-2008 11:50 PM
