High Inrush Current Measurements? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2013, 01:25 PM   #1
Rewards Points: 30
Just purchased a new Mastech MS2108 clamp-on meter which measures true RMS and inrush current (not to be confused with the cheaper, less capable MS2108A).
Measured current and inrush current on the Dometic 13,500 BTU a/c on my travel trailer. Measured 12.2 amps (continuous) while the compressor was on which seems like a reasonable reading. However, the inrush current for the compressor start-up is another story. I measured 58 amps! For comparison purposes (using the same meter) I also measured the current and inrush current on our microwave inside the house. It measured 13.2 amps. The start-up inrush current was 48 amps.
These inrush measurements seem very high. Is this possible, or do I have a very inaccurate meter? FWIW, followed the manufacturer's directions closely for measuring inrush current. They're very simple.
Thanks!
HomeGuy2 is offline   Reply With Quote
Old 10-05-2013, 01:38 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thanks!
Inrush current is generally 10 - 50 times larger than running.... this is why it is so important to size motor conductors, OCP, and ground fault and short circuit protection correctly....
Old 10-05-2013, 02:32 PM   #3
An old Tradesmen
Rewards Points: 6,540
On the compressor for your camper A/C, it will list its LRA. Its probably 52 to 54 amps. The rest of the inrush current was the fan motors.
Old 10-05-2013, 02:52 PM   #4
Rewards Points: 30
Stickboy1375 and beenthere, thanks for your replies! It's good to know my clamp-on meter is working properly. Now I see why some smaller generators have trouble powering a/c units on campers/TT's. That's a lot of start-up current!
Old 10-05-2013, 02:54 PM   #5
E2 Electrician
And people wonder why the lights dim on AC start ups....
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
Gac66610 (10-06-2013), Philly Master (10-06-2013)
Old 10-05-2013, 10:59 PM   #6
Rewards Points: 774
In my experience and we do a fair bit testing including inrush testing and 4-6 times is more typical, 10 times is high and 14 times is the highest I remember recording.
The 14 times was a ASCO ATS with open transition without an in-phase-monitor, very fast transfer time feeding a 75 kva transformer.
We utilize high speed line disturbance analyzers for inrush and waveform capture.
Know A Little is offline   Reply With Quote
Old 10-05-2013, 11:22 PM   #7
E2 Electrician
Probably correct, i googled for an average.... I really wasn't sure on the correct percentages... although, I didn't think the OP's numbers sounded too far off....
Old 10-06-2013, 12:25 AM   #8
7.5 times nameplate is my rule of thumb.
itsnotrequired is offline   Reply With Quote
Old 10-06-2013, 12:50 AM   #9
An old Tradesmen
Copeland Scroll compressor ZRD36KC-PFV, 13,500 BTUs. RLA 18.6, LRA 95
Copeland CL13KQ-PFV compressor, 13,500 BTUs. RLA 9.7, LRA 49
So HomeGuy2's reading was close, but probably lower then the real inrush was.
ZRD36KC-PFV
Old 10-06-2013, 06:50 PM   #10
Rewards Points: 774
There are so many variables regarding inrush, you might only get the worse case inrush every 8-10 starts
Old 10-06-2013, 07:06 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,122
As an FYI....inrush is a very difficult measurement to make. For example, where did the switch make in regard to the phase angle of the incoming ac? Was it as the 0 cross over, or was it at the peak? These variables will impact the actual inrush measurement....along with a lot of other things....like...what was the line loss...how good are the connections...etc.
The Following User Says Thank You to ddawg16 For This Useful Post:
mpoulton (10-06-2013)
High pressure operating Sdeclara HVAC 13 01-17-2012 03:44 PM
Carrier furnace short cycling between Low and High heat drtbk4ever HVAC 16 01-15-2012 09:38 AM
How high is too high for washer drain jcpiebald Plumbing 5 12-30-2011 08:42 PM
High Def TV with ExpressVu fjacky Home Theater 3 12-18-2011 08:35 AM
Rheem Criterion 2: high fan heat only dyincolor HVAC 2 03-27-2010 10:17 PM
