Old 01-05-2007, 03:27 PM   #1
high hats issue
Hi
I have high hats in my kitchen that are 20 years old.
The bulbs keep going out after 3 weeks of installing a new one ( 5 ligths on same wire). Do I need to replace the housing with a new one?
I checked the wiring with an ohmeter and it seems find as well as measuring for 110 when on. all looks well. I installed a dimmer switch on them as well and even under lower amperage they still go out very quickly. any other ideas?
Brian
brtims is offline   Reply With Quote
Old 01-05-2007, 05:27 PM   #2
high hats issue
what type of bulb are you using?
redline is offline   Reply With Quote
Old 01-05-2007, 07:53 PM   #3
high hats issue
Your typical high hats lightbuld. They look like small flood lights
Old 01-06-2007, 07:45 AM   #4
high hats issue
Are the bulbs burning out, or is the thermal overload tripping off?
Next time leave the burnt out bulb in for a while, and see if the light comes back on. Installing the wrong lamp in a can light can cause it to overheat.
jwhite is offline   Reply With Quote
Old 01-15-2007, 09:44 AM   #5
high hats issue
The bulbs are out. you can hear the rattling when you shake the bulb.
The opening is a 4" opening and I put a bulb in that fits perfect. Are there specific bulbs for different types of high hats?
Best High Temp Paint for wood stove?? Sellncars Painting 9 01-21-2009 07:21 PM
High pressure bjr23 Plumbing 1 03-27-2007 08:24 PM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 10:04 PM
high pitched tone from boiler? LanterDan HVAC 4 09-26-2006 08:40 PM
