-   -   high hats issue (http://www.diychatroom.com/f18/high-hats-issue-5748/)
brtims 01-05-2007 02:27 PM
high hats issue
Hi
I have high hats in my kitchen that are 20 years old.
The bulbs keep going out after 3 weeks of installing a new one ( 5 ligths on same wire). Do I need to replace the housing with a new one?
I checked the wiring with an ohmeter and it seems find as well as measuring for 110 when on. all looks well. I installed a dimmer switch on them as well and even under lower amperage they still go out very quickly. any other ideas?
Brian
redline 01-05-2007 04:27 PM
what type of bulb are you using?
brtims 01-05-2007 06:53 PM
Your typical high hats lightbuld. They look like small flood lights
jwhite 01-06-2007 06:45 AM
Are the bulbs burning out, or is the thermal overload tripping off?
Next time leave the burnt out bulb in for a while, and see if the light comes back on. Installing the wrong lamp in a can light can cause it to overheat.
brtims 01-15-2007 08:44 AM
The bulbs are out. you can hear the rattling when you shake the bulb.
The opening is a 4" opening and I put a bulb in that fits perfect. Are there specific bulbs for different types of high hats?
