High Hats Flashing - Electrical - DIY Chatroom Home Improvement Forum
Old 06-04-2013, 12:50 PM   #1
High Hats Flashing
Does this sound familiar to any electricians??
When I turn on one 3 way switch ALL of the lights flash in perfect rythm.
I just installed 2 sets of high hats in my basement. Both sets are on the same circuit. Both sets are on 3 ways switches(total 4 switches). It has been inspected and it has been working fine for the last few weeks. One set had low watt non-dim cfl's and th other set had LEDs. The set with the LEDs I replaced all but one bulb with the cfls. So yes I had 4 cfls and 1 Led. This is when the OTHER set began flashing. I removed the led so now both sets only have cfls and the problems continues. Again this only happens when using one of the 2 3way switches. The lights work like normal when I use the other switch.
Anybody??
Stcrosby is offline   Reply With Quote
Old 06-04-2013, 01:46 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,534
Boy...I don't know... sorta sounds like a bad travelor... but then it should be affecting the other switch also when they are on a different throw.
"ALL of the lights flash in perfect rythm".... Any chance your place is an old disco?..LOL
MTN REMODEL LLC is offline   Reply With Quote
Old 06-04-2013, 01:54 PM   #3
LOL There was orange and brown carpet over the old panel walls so who knows....
Ive confirmed power. Im going to try and swap out the switch.
What really puzzles me is that this just started happening after working correctly????
Old 06-04-2013, 01:58 PM   #4
joed's Avatar
Rewards Points: 12,458
From your description of only happening from one switch it sure sounds like a bad switch.
What happens if you turn the flashing off from the other switch and turn it back on from the original switch that made the flashing?
Old 06-04-2013, 06:52 PM   #5
Licensed Pro
Anybody??
Is one of the switches a dimmer?
Old 06-04-2013, 07:28 PM   #6
Is one of the switches a rythmic flasher
Soory... Just hada couple of cocktails after a good time
Old 06-04-2013, 08:48 PM   #7
Flashing again, But the other switch controls as normal.
Old 06-04-2013, 08:50 PM   #8
Each set of 3 ways has a one dimmer and one non dimmer. And Yes it is the dimmer that is causing the flashing. I will swap it out in the am and report back.
Old 06-04-2013, 10:09 PM   #9
House helper... My apologies for doubting your question.... I kinda assumed that Stcrosby might have mentioned that in his original post post.
What is your opinion... does he not have a three way dimmer...?
Old 06-05-2013, 12:18 AM   #10
" Euro " electrician
frenchelectrican's Avatar
What kind of dimmer switch and how you ran the switches in what fashion ?
I think you should try swap the traveller first to see if that clear up if not then you have a misconnection on the dimmer itself.
And where this dimmer is located in the first part of switch circuit or on the end of switch circuit ?
Merci,
Marc
Old 06-05-2013, 09:09 AM   #11
Licensed Pro
Non-dimmable CFLs + dimmer = flashing.
You need dimmable CFLs and a dimmer that is compatable.
The Following User Says Thank You to HouseHelper For This Useful Post:
MTN REMODEL LLC (06-05-2013)
Old 06-05-2013, 01:22 PM   #12
joed's Avatar
Exactly.
Old 06-05-2013, 04:28 PM   #13
The cfl's were thrown in to light the basement until I pony'd up for the LED's(since I have not heard of any dimmable cfl's worth a damn, any suggestions??) I knew the cfl's were not dimmable but I did not ecpext them to start going banannas, I just figured they would not dim.
And Im still curious as to why after a few weeks of working fine, then this occurred??
Anyway, I swapped out the switch with a non dimmer 3way and they are working fine.
The Following User Says Thank You to Stcrosby For This Useful Post:
HouseHelper (06-06-2013)
Old 06-05-2013, 07:49 PM   #14
joed's Avatar
Is the dimmer turn up to full? If the dimmer was on full before and someone adjusted it down to a dimming position that could account for it.
Old 06-05-2013, 08:14 PM   #15
Electrical Contractor
kbsparky's Avatar
Even set at "full" most dimmers are still dimming a little bit.
You can't use standard dimmers on most CFL and LED applications.
-KB
Flashing replacement question daluu Roofing/Siding 16 01-26-2012 08:36 PM
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 10:27 AM
Which flashing tape for Chimney flashing? gante Building & Construction 9 03-19-2009 10:27 AM
Spacing of high hats ? iMisspell Electrical 8 11-29-2008 08:12 PM
proper steps in wrapping tyvek and flashing windows?? 4just1don Building & Construction 4 11-17-2008 06:10 PM
