Hiding Ac Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 12-08-2012, 10:38 PM   #1
Rewards Points: 117
hiding ac outlets
im doing a room redo. i want to put in rope lighting for accent lighting. however i cant seem to find direct wire rope light. so im left with plugin type. the thing is i do not want the plug to show and i dont want to keep having to unplug and plug it back in so i was thinking of putting in a recessed outlet and hiding the outlet with a "trapdoor" and controling the outlet with a wall switch.
im looking for thoughts, opinions and suggestions on this idea.
thanks
echobravo is offline   Reply With Quote
Old 12-09-2012, 09:45 AM   #2
Rewards Points: 150
That was the first thing I thought of.
Another idea is some kind of valence which hides the outlet from view, but wouldn't involve a recessed outlet.
Dave632 is offline   Reply With Quote
Old 12-09-2012, 11:12 AM   #3
Rewards Points: 81
I did something similar in my kitchen, with rope lights sitting on top of the cabinets to provide accent lighting. I put a single gang box, mounted horizontally, right at the top edge of the cabinet. The outlet is a switched split duplex with one plug for the rope lights, and the second for the under-cabinet puck lights. I painted the outlet covers to match the wall. With the outlets being much higher than eye level, plus blocked by crown molding, they are really not noticeable. At 6'1", if I stand way back and look for them I can see the top of the wall plate.
tev9999 is offline   Reply With Quote
Old 12-10-2012, 02:55 PM   #4
Rewards Points: 117
thanks all appreciate the input
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Gfi outlets keep tripping but not constantly INEEDHELPPLZ1 Electrical 22 09-30-2011 09:28 AM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 03:22 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 09:49 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
