05-29-2012, 12:21 PM
#106
Hide/Cover Sconce Light Fixture hole
Originally Posted by Code05
It is not defined in the NEC specifically. However 90.4 allows an AHJ to interpret or define it, and many go with a ROP short of a formal interpretation.
And it is "termination point".
Yes, the termination point is the point of termination. A loose wire has no termination point since it has not been terminated by the definition that the NEC uses in any of the many hundreds of times that it uses the word.
Words have many definitions. All of those definitions do not apply each time a word is used. For example, the word terminate can be defined as "assassinate, kill". However, we all know that doesn't apply to the way we use the word in our trade and in the NEC. The same for the definition "end". No one in our trade has ever told someone to "make that termination" and that person came back and said "it's already ended in mid air!". No where in the NEC is the word "termination" use to define the end of the wire, out of hundreds of times it's used...
05-29-2012, 12:28 PM
#107
Licensed electrician
Would you also argue with the police that pulled you over for the illegal U turn that they could not because you swung wide right before going left which caused your turn to be shaped like a P?
We have shown numerous times that the word terminate or terminal can have differing meaning. You choose to focus on only one of those. I have replied with the common or dictionary usage of the word temination as being the endpoint of something. I don't believe you answered what you would call the finite endpoint of the cable if it is not a terminal end.
05-29-2012, 12:31 PM
#108
Licensed Electrician
Why can I not let this die.
The NEC DOES NOT amend the definition of termination point to mean something other than what the dictionary defines it as. Therefore, whether you like it or not, the definition of termination point of a wire, is the end point of the wire, whether it is connected to something or capped off.
It can't be said any clearer than this, if you are interpreting it as anything other than this, you are wrong. If you have any other evidence, other than inferring a definition other than what is written, I will be happy to look at it. Show me a written interpretation that in some way confirms your position that it is OK to bury the end of a live wire in a wall, nowhere have you shown that, you have just reiterated your personal definition of the word termination point.
05-29-2012, 12:35 PM
#109
Why act childish? Is it because you mistakenly thought that a box with a splice in it couldn't be buried for safety reasons?
You haven't shown me that, I knew that since childhood vocabulary class.
Well, maybe more than one. However, as I said, not ALL of the definitions are applicable. We aren't using the definition "assassinate, kill" when we say terminate, right?
Again, there are many definitions, not all of them apply. We know how the NEC defines the word because it's used hundreds of times. And, as I said, in none of those instances is it talking about the loose end of a wire. This is a FACT that you have ignored for the last 3 pages. Why not just admit to it?
Not sure what you mean...? It's the end of the cable, but as far as the NEC, the cable is NOT terminated if it's loose and hanging in the air.
05-29-2012, 12:41 PM
#110
That's incorrect. The NEC does not use the word Termination to define the loose end of a wire in any of the hundreds of instances that it uses the word. I've said this 20 times but every time it's ignored. The NEC uses specific definitions of each word that it prints. Not all definitions apply. Like I said, the definition "assassinate, kill" is not the meaning of the word terminate when used in the NEC, just like the end of a loose wire is not the definition either.
This is incorrect. Neither the NEC nor electricians use the word Termination to define the loose end of a wire. It just doesn't happen.
No, you are wrong
I've backed up my claim with evidence the entire time, while people won't even answer a simple question after asking it 20 times. Jeeze!
Show me a written interpretation of the word Terminate as used in the NEC that EVER means the loose end of a wire.
If it's not restricted, then it is OK to do.
It's not my personal definition, it's the way that the NEC uses it. How many more times do I have to say that? Just the fact that I've said it 21 times now and you still say that it's "my personal definition" shows that you haven't followed along at all.
For the 22nd time, the NEC DOES NOT define the word Terminate as the end of a loose wire in ANY of the hundreds of times it's used. So why change the definition for this one time?
05-29-2012, 12:51 PM
#111
I want to thank you guys. I checked the job specs of one of our big jobs and it says we have to "~make up all cable terminations for power, data, and antenna signal~".
After reading this thread I know that I can just cut the wires and call it done!!
If you don't mind, I'd like to have each one of your names and addresses so I can have the subpoena sent to you so you can come to court and defend us as expert witnesses when we get the crap sued out of us for breach of contract, thanks
05-29-2012, 12:54 PM
#112
Lawyer: Were you at the party where the person was stabbed?
Yes, but I was in the bathroom at the time.
L: A yes or no answer only.
Yes
Makes quite a bit of difference when the context is not known or has been changed and is not allowed to be qualified.
05-29-2012, 12:55 PM
#113
Yes
Context is great. And in the context of the NEC, the word terminate has NEVER been used to speak about the loose end of a wire, not in all the hundreds of time it's been used. Context
05-29-2012, 01:01 PM
#114
If I put tape or wire nuts on the end is the cable now terminated?
I don't see why it is so hard to see that not everything uses the NEC to define a word. Many times we need to revert to everyday English meanings.
While the intent or concept cannot be enforced, it will certainly be used in forming a decision should the AHJ be asked to make a ruling on the subject.
#115
You are correct, the word terminate is what you do to a loose end of a wire...and the end of a wire is the termination point of the wire...or the part of the wire you terminate.
The Following User Says Thank You to k_buz For This Useful Post:
05-29-2012, 01:05 PM
#116
How many times has this been discussed?
You are ABSOLUTELY CORRECT. Not everything uses the NEC to define a word. Such as the movie Terminator, it's definitely not using the NEC's definition of the word, right?
However, the NEC uses the NEC to define the words  And since we are talking about the NEC, i think it's very reasonable to go by it's own definitions.
You are 100% correct.
05-29-2012, 01:07 PM
#117
Cool, we agree. When nothing is done to that loose end of the wire, it's not terminated.
Only if it has been terminated. If it hasn't been terminated, it's not the termination point.
Exactly, it needs to be terminated in order to be a termination point.
05-29-2012, 01:09 PM
#118
JOATMON
Ok....show us in the NEC where it defines the loose end of a wire....without using exclusionary logic.
Wrong....I use it all the time....
No, you are wrong
No....you have not backed up your claim. You have failed to show us in the NEC where it explicitly defines " loose end of a wire"
Your 'trying' to use exclusionary logic to show that the loose end of a wire is not terminated. Under the accepted/publised definitions of Terminate/Terminated/Termination....a loose wire is terminated.....
This is what a Thasaurus shows for 'terminate'
Synonyms break off, break up, close, conclude, dead-end, determine, die, discontinue, elapse, end, expire, finish, go, halt, lapse, leave off, let up, pass, quit, stop, terminate, wind up, wink (out)
So....according to the Webster Thesaurus....End is a synonym to Terminate.....so using non-lawyer logic....loose end of a wire would also mean 'terminate'.....
Any futher contrary conclusions you have to this logic will only confirm that you have no logic....
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
05-29-2012, 01:10 PM
#119
This is not acting childish. That example was purposely done to show how words can be twisted.
Show me where this is allowed. How about asking the professional sites like at Mike Holt or Electrician Talk?
You could also search this site for someone that also thought it was safe to bury a splice as there was no way for it to fail and was shown differently.
05-29-2012, 01:21 PM
#120
Why would the loose end of a wire have to be defined? Isn't it clear enough already?
You're not an electrician, I can't expect you to know how the NEC works.
You're not an electrician nor do you know anything about the NEC.
And you do NOT use the word "termination" to describe the loose end of a wire, so stop lying...
No....you have not backed up your claim. You have failed to show us in the NEC where it explicitly defines "loose end of a wire"
Again, why would I do that? What purpose would it be? Why would the NEC ever need to define a group of words that are very descriptive.
Here, I'll do it for you:
The loose end of a wire
Definition: The loose end of a wire.
I'm using logic as well as common sense, context, and experience with the NEC. What are YOU using?
No, a loose wire is NOT terminated by the definition that the NEC uses.
it doesn't make a difference what the thesaurus says, not ALL synonyms or definitions are applicable. Just like I said earlier, the NEC doesn't use the definition "Assassinate, Kill" to define the word Termination even tho the dictionary has that as one of the many definitions. What is so hard to understand about that?
No, it wouldn't. Not unless you are trying to say that when the NEC says "termination" they mean a killed or assassinated wire
Yes, there it is    You can't prove your side so you try to insult me
Even if I had no logic, I still hold a contractor's/master's license in NJ and NY so I certainly know the NEC, which is the only thing that matters in this discussion. Go find some wood to butcher
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
