Closed Thread
Old 05-29-2012, 11:41 AM   #91
Code05's Avatar
Hide/Cover Sconce Light Fixture hole
Originally Posted by Macro View Post
I disagree. Not all inspectors will red tag it. As I mentioned, it is very common to tape off K&T wiring. Maybe it's just a regional thing, you may not have as many old houses as we do in this area. But we can't go assuming what all inspectors will do.
K&T installs are a whole beast to themselves, but you can longer splice, tap, or terminate it like they did it the old days.
I've never had an argument in real life since it's always been acceptable. I've had discussions online, this is the only time that other people got so heated about it tho
I am not heated a bit.
Code05 is offline
Old 05-29-2012, 11:44 AM   #92
Licensed Electrician
k_buz's Avatar
My contention is that they (terminations) all are used to describe what you do to the end of a wire.
A wire nut can be a termination
A lug can be a termination
A ground screw can be a termination
A neutral bar can be a termination
More generally, a termination is a way to terminate the wiring...or end the wiring, and you cannot terminate a wire/cable anywhere but the end of the wire. Therefore, the termination point of a wire/cable is the end of the wire and must be in a box or conduit body.
k_buz is offline
The Following User Says Thank You to k_buz For This Useful Post:
Jim Port (05-29-2012)
Old 05-29-2012, 11:47 AM   #93
I assume you meant to say that "you can no longer...".
If so, then things are different around here. Taping off K&T is common practice, and I don't see anything restricting it or romex in the code.
Me neither
Macro is offline
Old 05-29-2012, 11:51 AM   #94
k_buz's Avatar
Me neither
Knob and Tube wiring is not listed as one of the wiring methods that 300.15 requires a box or conduit body at termination points. 300.15 does list two specific termination points that they are required however.
k_buz is offline
Old 05-29-2012, 11:52 AM   #95
In all of the hundreds of instances in the code that we know about, I don't know of a single one that refers to the loose end of a wire. If you know of one, then please cite it, I would genuinely like to know since I am here and enjoy discussions like this to learn.
A termination in all instances in code and in electrical speak is to attach that loose end to something. Taping off a loose wire is not terminating it.
EVERY wire has an end somewhere, but not all wires are terminated.
Again, show me where the loose end of a wire is defined as terminated in any of the hundreds of places the word is used in the NEC. The fact that I have asked this question literally 11 times and no one has answered it pretty much proves the point that the NEC does not see the word "terminated" as the loose end of a wire.
Macro is offline
Old 05-29-2012, 11:55 AM   #96
I agree with all of this. My examples of taping off K&T wiring no longer applies to this discussion.
Macro is offline
Old 05-29-2012, 11:59 AM   #97
k_buz's Avatar
edit..
k_buz is offline
Old 05-29-2012, 12:05 PM   #98
Code05's Avatar
yes, thank you
If it is existing and you do not touch it, fine: but any alterations must be brought to modern code. I wanted to leave K&T out of this because it was installed without boxes to start. Kinda muddles the thread a bit.
Me neither
Good
Code05 is offline
Old 05-29-2012, 12:06 PM   #99
You are changing the discussion by asking what a termination is.
I'm not changing the discussion. I started the discussion and I have been discussing the same exact thing since my first post
I have answered that question.
LOL, WHERE?
The code rule we are citing doesn't include the word terminations.
SORRY!!!!!! Leave off the last S for savings!!!!!!!!!
It doesn't include the word "terminations" but it does include the word "termination" with no S.
The code rule is "each conductor termination point". All wires/cables have two termination points, and those termination points need to be accessible.
The termination point is the point of termination. There is no point of termination when a wire is not terminated, as in the case of a loose wire.
My question still remains. Why change the definition of "termination" for this one instance when it goes against the hundreds of other times the NEC uses the word?
Macro is offline
Old 05-29-2012, 12:11 PM   #100
k_buz was right about K&T being different anyway, as discussed in post #96.
Macro is offline
Old 05-29-2012, 12:13 PM   #101
JOATMON
ddawg16's Avatar
ter·mi·na·tion (tūrm-nshn)
n. 1. The act of terminating or the condition of being terminated.
2. a. The end of something in time; the conclusion.
b. An end of something in space; a limit or edge.
3. A result; an outcome.
4. Linguistics The end of a word, as a suffix, inflectional ending, or final morpheme
I just searched the 2008 NEC PDF for the word "Termination"*. There are 129 pages that have that word on it, some of the pages have the word 2, 3, or even up to 6 times. That means the word is used many hundreds of times in the NEC.
Out of hundreds of times the word has been used in the code, can you show an example of just one time that it is used to define a loose hanging wire not connected to anything on that end?
Can you show where it is used in normal electrical speak?
Out of the hundreds of times it's used in the code and the millions of times it's used in electrical discussions, if it's never used to define the loose end of a cable, why should we change the definition for that one instance?
The loose end of a wire is actually the exact polar opposite of what most electrician would consider "terminated".
* I only searched for the word "Termination". I did not search for "terminate" or any other variant. If I did, I'm sure there would be hundreds of more instances where it's used.
Your starting to sound like a lawyer.....you might want to look up "Inclusionary" vs "Exclusionary".
The termination point of a wire is where the wire is terminated. If the wire is not terminated, there is no termination point.
You ignored the question in post #87 yet again
Wrong....
terminatedpast participle, past tense of ter·mi·nate (Verb)
Verb:
  • Bring to an end: "he was advised to terminate the contract".
  • (of a thing) Have its end at (a specified place) or of (a specified form): "the chain terminated in a ball covered with spikes".
ter·mi·nate
   /ˈtɜrməˌneɪt/ Show Spelled [tur-muh-neyt] Show IPA verb, ter·mi·nat·ed, ter·mi·nat·ing.
verb (used with object) 1. to bring to an end; put an end to: to terminate a contract.
2. to occur at or form the conclusion of: The countess's soliloquy terminates the play.
3. to bound or limit spatially; form or be situated at the extremity of.
4. to dismiss from a job; fire: to terminate employees during a recession.
No mater how hard you try to use inclusionary or exclusionary logic....one or more wires that just end....hooked up or not...live are not....are 'terminated'....
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is offline
Old 05-29-2012, 12:14 PM   #102
Code05's Avatar
It is not defined in the NEC specifically. However 90.4 allows an AHJ to interpret or define it, and many go with a ROP short of a formal interpretation.
And it is "termination point".
Code05 is offline
Old 05-29-2012, 12:17 PM   #103
k_buz's Avatar
The definition of termination isn't changing, you are just failing to accept one acceptable way to terminate a wire is to put a wirenut on it. You say it isn't a termination, the rest of us say it is.
I am done.
k_buz is offline
Old 05-29-2012, 12:17 PM   #104
Who better than a lawyer to interpret law??
Wrong....
No, what I said is very correct.
No, they are not.
You haven't brought anything new to the discussion, you've said the same thing that has been said 15 times already in this thread. Do you really want to go back and forth when you could just read what has been said earlier?
Macro is offline
Old 05-29-2012, 12:19 PM   #105
Yes, exactly. This was a well know fact since the beginning of the thread. There are people who see it your way and there are people who see it mine (altho only one of them is here in this thread and he's been gone for hours, leaving me all alone ). The fact is that the code is not clear at all and it can be interpreted either way. That's what I said at the very beginning.
Macro is offline
Closed Thread
How many wires can be tapped into a light fixture? JayBird Electrical 6 07-11-2011 03:44 PM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 10:26 PM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 50 09-01-2009 09:20 PM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 09:08 AM
I can feel buzzing or "charged" air around a light fixture? jabrockson Electrical 10 03-26-2009 09:20 PM
