Closed Thread
Old 05-28-2012, 07:39 PM   #16
Hide/Cover Sconce Light Fixture hole
Originally Posted by Jim Port View Post
Here is 300.15 which I also agree would apply. Blue by me for emphasis.
300.15 Boxes, Conduit Bodies, or Fittings —Where Required.
A box shall be installed at each outlet and switch
point for concealed knob-and-tube wiring.
Fittings and connectors shall be used only with the specific
wiring methods for which they are designed and listed.
Where the wiring method is conduit, tubing, Type AC
cable, Type MC cable, Type MI cable, nonmetallic-sheathed
cable, or other cables,[COLOR="rgb(65, 105, 225)"] a box or conduit body shall be installed
at each conductor [/COLOR]splice point, outlet point, switch point, junction
point, termination point, or pull point, unless otherwise
permitted in 300.15(A) through (L).
I edited my last post to cover that. The wire is not terminated, which is why that article doesn't apply. I believe it was Marc Shunk, a Moderator at this forums sister site Electriciantalk.com, who went into detail about this.
Macro is offline
Old 05-28-2012, 07:40 PM   #17
Licensed electrician
Termination could also mean an endpoint.
Jim Port is offline
Old 05-28-2012, 07:42 PM   #18
It could, but does it mean that in electrical code?
When I tell a worker to terminate a set of wires, I want them landed on the lugs, not dangling in the air
Macro is offline
Old 05-28-2012, 07:45 PM   #19
And the lugs would be in some kind of a box or enclosure, correct? You would not have a flying splice like the old K&T or an improperly made splice outside of a box.
Jim Port is offline
Old 05-28-2012, 07:45 PM   #20
Code05's Avatar
Personally I think the end of an energized cable/conductor is an outlet point in that section. But I can live with either.
Code05 is offline
Old 05-28-2012, 07:46 PM   #21
E2 Electrician
stickboy1375's Avatar
personally, I don't have an issue with it, and I just don't see the violation... when costs don't hinder the job, I will try to disconnect where it is fed from, but yeah, if I have to take a fixture down, its not happening.
stickboy1375 is offline
Old 05-28-2012, 07:47 PM   #22
Code05's Avatar
What is the definition of outlet point?
Code05 is offline
Old 05-28-2012, 07:48 PM   #23
E2 Electrician
All of those would require a box, were talking about a dead ended wire.
Old 05-28-2012, 07:50 PM   #24
As I see the cable as a deadend I would not say the cable would would meet the NEC definition of an outlet. Potential outlet, maybe if it were re-purposed. I only say this as no current is being taken.
Outlet. A point on the wiring system at which current is
taken to supply utilization equipment.
Jim Port is offline
Old 05-28-2012, 08:17 PM   #25
Yes, lugs would be in an enclosure. But an abandoned live wire wouldn't be in an enclosure nor would it be terminated. We're not talking about splices here.
Macro is offline
Old 05-28-2012, 08:19 PM   #26
I do not know what an "outlet point" is, but Jim defined "Outlet".
I don't believe that a loose wire in a wall would be either.
Macro is offline
Old 05-28-2012, 08:41 PM   #27
Code05's Avatar
As stated, there is no definition of out point- so as far as I am concerned it is the point where the actual current is supplied: the end of the energized wire.
Code05 is offline
Old 05-28-2012, 08:54 PM   #28
So let me pose this, a live splice would need to be in an accessible junction box, but a live deadended cable in a box could be buried?
I certainly don't think that is the intent.
Jim Port is offline
Old 05-28-2012, 09:18 PM   #29
Code05's Avatar
If you are asking me, I already agreed. 300.15 prohibits IMO.
Code05 is offline
Old 05-28-2012, 09:20 PM   #30
I thought you did agree D, but I thought the others did not and was looking to see other thoughts.
Jim Port is offline
Closed Thread
How many wires can be tapped into a light fixture? JayBird Electrical 6 07-11-2011 03:44 PM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 10:26 PM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 50 09-01-2009 09:20 PM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 09:08 AM
I can feel buzzing or "charged" air around a light fixture? jabrockson Electrical 10 03-26-2009 09:20 PM
