#136 |
Licensed Electrician
Hide/Cover Sconce Light Fixture hole
The ROP was never posted in the thread you are referencing, I don't know this for sure, but maybe Marc would have sung a different tune if he had all the information?
#137 | |
Hide/Cover Sconce Light Fixture holeQuote:
Again, the ROP is meaningless in this discussion. I conceded on the second page that the intention may have been to restrict it, but the written word does NOT. I also gave another example of intention being different than the written word when citing that you can install receptacles on a 15A general purpose circuit in the bathroom. This is FAR from the first time that the CMP has had to clear up a stupid code entry that could be interpreted many different ways. |
#138 |
JOATMON
Ok....I see what is going on.....Marco is just using this to get his post count up.....
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#139 | ||
This was my question....
Now that we got that cleared up, why would it be against code to bury a box with one 14-2 NM in it, but legal to bury a 14-2 NM without a box on it. Please, give me one logical reason. |
#140 | |
Licensed electrician
Regardless the only opinion that matters is the one from the CMP and they said a box is required. You will also note that Marc said he was picking the one he agreed with. Just becuase you agree with something does not negate the fact that others may not see it your way.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
#141 | |
If at any time you choose to actually respond to my posts that refuted everything you said, feel free. Until then, you can keep ignorantly spewing nonsense on topics you don't understand because your long list of achievements in the electrical world (member of a DIY forum for 8 months and some work on your own house) surely make you qualified to interprete code.
#142 | |||
Marc went to Nathan to talk about opening an electrical forum and Nathan started it up and put Marc in control.
I understand that you are going to say that the CMP writes the NEC and all that. But in the end, the NEC is adopted and what is written in it when it's adopted is all that counts. Quote:
The problem here is that code should NEVER be left up to opinion. Not when it's using a word that no where else in the NEC nor in electrical nomenclature is it used to mean the loose end of a wire. But ddawg16 said that he uses the word termination to mean the end of a loose wire all the time, so I guess this issue is settled. Quote:
#143 | |
That is not only logical, it is an indisputable FACT. It's not an opinion, if the code doesn't prohibit something, it is legal. Fact, fact, fact. |
#144 |
That is the part you aren't grasping either from ignorance or stubbornness. It IS specifically prohibited when the NEC states that the termination points need to be in a box.
Just because an electrician doesn't interpret termination point to mean what the actual definition of termination point is, doesn't make the situation legal. You have been provided with written evidence that what you are proposing is against code (the ROP), you show us one thing from someone of authority in the electrical field that supports your claim. If you can do that, I will concede that this issue will be up the discretion of the AHJ. |
#145 | |||||
That's where i am coming from, if you can't understand that we have a difference of opinion than I don't know what more to say. Quote:
#146 | |
JOATMON
![]() and this... ![]() The fact that the panels are UL compliant doesn't mean anything....and all the field wiring is per NEC....including all terminated and un-terminated wiring....and all those spare wires that are just coiled up and stored in a box.... Nope...I don't know anything.....
#147 | ||||
You can show me that you are a brain surgeon, or an astronaut, or a physicist. It doesn't matter because none of those professions, just like yours, have anything to do with the NEC. I'm starting to question the validity of your assertions as to how smart you are, since you can't understand simple, basic English. Once again, you don't know jack about the NEC (as you admitted), so you are not qualified to tell me what a word that is used hundreds of times in it means. The same way as I am not going to come to you and argue with you about what that big shiny thing in the picture is. Quote:
![]() ![]() ![]() Quote:
#148 |
Fellas at this point we are being trolled by some ET guy that cannot make it at MH. I am done. Bye Macaroni.
Dude, if ET is your only source, I feel sorry for ya. |
#149 |
I don't even think Cletis would troll this hard.
#150 |
For people looking at this thread for information (not that I think they would read all this crap to get to this point) abandoning a live wire in a wall or ceiling is not standard practice. If this was done, any inspector would require that live ends of a cable be dead-ended in a box.
| Display Modes | |
| How many wires can be tapped into a light fixture? | JayBird | Electrical | 6 | 07-11-2011 03:44 PM |
| Help with wiring a new light fixture | tinkin3 | Electrical | 10 | 09-09-2009 10:26 PM |
| Please Help! 3 way switches controling 2 light fxtures. | HelloMotto | Electrical | 50 | 09-01-2009 09:20 PM |
| Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. | Deck | Electrical | 8 | 08-26-2009 09:08 AM |
| I can feel buzzing or "charged" air around a light fixture? | jabrockson | Electrical | 10 | 03-26-2009 09:20 PM |
