Hide/Cover Sconce Light Fixture Hole - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 05-26-2012, 05:50 PM   #1
Hide/Cover Sconce Light Fixture hole
Want to remove electrical sconces on bedroom walls. Would prefer not to cover the holes or hide with pictures. Can these holes be patched? Can wires be removed? Is this a fire hazard?
cgordonrogers is offline
Old 05-26-2012, 05:54 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
In order to patch up the holes you will have to remove the boxes. If you remove the boxes, you have to pull back the wires to the next box or install a box in which to terminate the wires.
It's not a fire hazard to have unconnected wires as long as they have wire nuts on them.
ddawg16 is offline
Old 05-26-2012, 11:49 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Welcome to the Forum.
Tell us about your bedroom sconces. Are they wired with Romex type wire? If you don't know how to tell the difference then you may be safer by calling an Electrician?
Disclaimer
& Stay Safe
.....Bob Lavery
PaliBob is offline
Old 05-27-2012, 12:11 AM   #4
Master Electrician
you can get decorative blanks to fit the boxes as well, or get whites and paint them to match the room.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline
Old 05-27-2012, 07:51 AM   #5
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
or buy nicer sconces and just install them instead.
stickboy1375 is offline
Old 05-28-2012, 04:36 PM   #6
If these sconces are wired in the "switch leg" fashion (power goes to switch first, then a switch leg is run to the sconces) all you need to do is disconnect the wire in the switch box. Then you can patch the holes, burying the box is fine.
Some will say that even if the lights were wired in the "switch loop" fashion (power goes to the light box first, then a switch loop runs over to the switch) you can just cap the wires off and then bury the box because there is no connection inside of the box.
Macro is offline
Old 05-28-2012, 04:42 PM   #7
Licensed electrician
Rewards Points: 1,766
Energized ends of a cable cannot be buried in the wall.
Jim Port is offline
Old 05-28-2012, 04:45 PM   #8
You know what comes next: Article?
Edited: There is a lot of discussion on this topic, it goes both ways. Here is an example: http://www.electriciantalk.com/f2/hack-12483/
The main reason why you can't bury a junction box isn't a safety issue, it's in case the splices ever came loose, it's easier to troubleshoot when you can actually find the box. When abandoning wires and capping them off, there is nothing to come loose.
I don't think the thread starter should have this issue anyway since I am guessing the sconces are fed with a switch leg and he could just disconnect the wires inside of the switch box and abandon them properly.
Macro is offline
Old 05-28-2012, 04:48 PM   #9
E2 Electrician
Haha, I agree.
Old 05-28-2012, 05:45 PM   #10
If it is still energized I would think this would apply.
314.29 Boxes, Conduit Bodies, and Handhole Enclosures
to Be Accessible. Boxes, conduit bodies, and handhole
enclosures shall be installed so that the wiring contained
in them can be rendered accessible without removing
any part of the building or, in underground circuits, without
excavating sidewalks, paving, earth, or other substance that
is to be used to establish the finished grade.
Jim Port is offline
Old 05-28-2012, 05:54 PM   #11
E2 Electrician
That section only contains Boxes, Conduit Bodies, and Handhold enclosures that contain wires....
Old 05-28-2012, 06:10 PM   #12
This is the part I was addressing.
If the conductors have been de-energized and removed from the box I would agree that it could be abandoned and covered over.
Jim Port is offline
Old 05-28-2012, 06:23 PM   #13
Code05's Avatar
Rewards Points: 1,104
This most applicable article is 300.15 IMO. Depends how you read it. I agree with you, but many will not.
Code05 is offline
Old 05-28-2012, 06:35 PM   #14
This topic is completely up in the air, different people see it in different ways.
One can say that if you pull a cable out of a box and tape it off, it's legal to bury it in the wall live. 300.15 wouldn't cover this since the wire isn't being spliced, terminated, etc. I linked to one thread where they were discussing that and there are many others.
Macro is offline
Old 05-28-2012, 06:37 PM   #15
Here is 300.15 which I also agree would apply. Blue by me for emphasis.
300.15 Boxes, Conduit Bodies, or Fittings —Where Required.
A box shall be installed at each outlet and switch
point for concealed knob-and-tube wiring.
Fittings and connectors shall be used only with the specific
wiring methods for which they are designed and listed.
Where the wiring method is conduit, tubing, Type AC
cable, Type MC cable, Type MI cable, nonmetallic-sheathed
cable, or other cables,[COLOR="rgb(65, 105, 225)"] a box or conduit body shall be installed
at each conductor [/COLOR]splice point, outlet point, switch point, junction
point, termination point, or pull point, unless otherwise
permitted in 300.15(A) through (L).
Jim Port is offline
Closed Thread
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
How many wires can be tapped into a light fixture? JayBird Electrical 6 07-11-2011 02:44 PM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 09:26 PM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 08:08 AM
I can feel buzzing or "charged" air around a light fixture? jabrockson Electrical 10 03-26-2009 08:20 PM
