Hidden Door With An Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 05:14 PM   #1
Question
Hidden Door with an Outlet
I am finishing my basement which includes a home theater. Behind Where I plan on mounting my 60in led flat screen is the foundation that supports my brick chimney--basically a 2ft x 2 ft area above which is the fireplace and chimney. The tv is going to be mounted on hidden door that opens to safe. My problem is that I need to have a power outlet behind the tv and I am not sure how to run wiring through the door frame and into the door.
I've looked at power transfer hinges but they, it would appear, cannot handle the amps/volts needed to support the outlet. I also saw a device used by security companies when they wire doors with electric strikes. However, it is only good for 24 volts or so. Finally, I looked at using wire that is rated for high flexibility but I am not sure it is the right solution either.
Has anyone ever done something like this or have some ideas how I can do this?
I would really appreciate some advice on how (or even if) I should proceed.
Thanks.
Smbarney is offline   Reply With Quote
Old 02-03-2012, 06:33 PM   #2
Rewards Points: 6,652
Flexible Metal conduit.
The Following User Says Thank You to gregzoll For This Useful Post:
plummen (02-03-2012)
Switched Outlet Issue mjm Electrical 13 06-14-2015 08:56 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
