Hi Need Help To Replace Doorbell - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2010, 03:47 PM   #1
Hi need help to replace doorbell
Hi, amazingly using search on DIY could not find any assistance in replacing an old defective doorbell. Can anyone help, Carol
hagercj2315 is offline   Reply With Quote
Old 03-28-2010, 06:59 PM   #2
water flows downhill
oarfish's Avatar
The button outside should have 2 wires to connect.
The actual door bell inside the house may have 2 wires or more depending on how many entrance doors ar belled.
It should be easy connecting the new ones the same way the old one is connected.
12V is less dangerous as well.
oarfish is offline   Reply With Quote
Old 03-28-2010, 08:25 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Originally Posted by hagercj2315 View Post
.......replacing an old defective doorbell.
Carol,Welcome to the Forum
How do you know what is wrong, other than the doorbell does not sound?
The wired doorbell circuit has four parts
1) doorbell push button switch
2) low voltage transformer
3) bell or chime mechanism
4) Wiring to interconnect the switch-transformer-bell
Trouble shooting a doorbell is straightforward and usually fairly easy if the existing interconnecting wiring is OK
If you want to install a wireless battery powered doorbell there are many sources from hardware stores, Big Box stores, and through the net e.g.
http://www.amazon.com/Honeywell-RCWL..._ptcn_edpp_url.
Carol tell us what you want to do
Make existing bell work? (if it is a wired bell)
or install a new wireless bell?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-29-2010, 12:01 AM   #4
A search of google.com for the words...
wire doorbell
...gets all sorts of information. Here is the link...
http://www.google.com/#hl=en&source=...6b5a4f84435186
Billy_Bob is offline   Reply With Quote
Tags
replace doorbell
Doorbell Question captainron19 Electrical 21 03-05-2010 04:40 PM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 01:54 PM
replace galvanized pipe below kitchen sink? Jeremy Hillary Boob, PhD Plumbing 3 04-03-2009 08:39 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
how to replace, or maybe swap, this odd doorbell setup joeyboy General DIY Discussions 7 12-16-2007 12:53 PM
