Hi Im New! Need A Little Help With Installing Light Fixture! - Electrical - DIY Chatroom Home Improvement Forum
Old 07-02-2011, 06:46 PM   #1
hi im new! need a little help with installing light fixture!
so i removed my old ceiling fan and instead of there being a box there were just three wires coming out of the ceiling, one black, one green, and the other seems to be black aswell but wrapped with electrical tape? cant tell. i already put on the bracket for the new light fixture and attached the ground wire, and tried connecting the wires but no luck..maybe this pic will help..if at all possible i would like to get it up and running without a box temporarily then this week on my day off do it the right way...thanks and any input is much appreciated.
mrogers00000 is offline   Reply With Quote
Old 07-02-2011, 07:31 PM   #2
DIY staff
Rewards Points: 7,174
Do you have a tester of any kind? You need to figure out which is the power coming from the switch and which is the neutral.
There is a switch isn't there?
Cheap neon testers only cost $2.00 or so---Mike----
Old 07-02-2011, 07:35 PM   #3
thanks for the answer! yes theres a dimmer switch..ill go buy a tester real quick
edit: will a OEM 12 volt circuit tester work? its meant for automobile use thats why i ask if its the same
Old 07-02-2011, 07:46 PM   #4
DIY staff
No you will pop that thing. 120 volts.
Old 07-02-2011, 08:48 PM   #5
ok i got this, good up to 250v...dont really know how to use one of these though...sorry ive never done anything like this before man
edit: just tested both black wires using the non-contact method and its indicating that both are live..is that possible?
Old 07-02-2011, 08:53 PM   #6
Electrician
SD515's Avatar
Rewards Points: 504
Looks like a knob & tube neutral, the one you said is wrapped with tape. Be careful, it could be live.
You wouldn’t believe how many times I’ve seen a switched neutral on knob & tube wiring.
Kyle
Old 07-02-2011, 08:57 PM   #7
SD i really appreciate the reply but do you mind explaining to me what knob and tube wiring is? lol
Old 07-02-2011, 09:00 PM   #8
Electrician
SD515's Avatar
Rewards Points: 504
Problem with non-contact voltage testers, they only detect the presence of voltage, not the amount. Those can beep or light-up with as little as 20 or so volts. Not very useful for in-depth troubleshooting. You really need a multi-meter for testing, if you truly want to know what’s going on.
When I troubleshoot K&T wiring, I use my meter and an extension cord plugged into a known grounded receptacle.
Kyle
Old 07-02-2011, 09:09 PM   #9
Electrician
SD515's Avatar
Rewards Points: 504
Here's some K & T pictures...
Kyle
Old 07-02-2011, 09:09 PM   #10
thanks for the info! ill go exchange it right now!
Old 07-02-2011, 09:11 PM   #11
oh i see! so if i find out which is hot and which is neutral can i even hook up those modern wires to the ones in the ceiling?
Old 07-02-2011, 09:13 PM   #12
RKRider's Avatar
You could also be holding the tester to so that there isn't enough distance between the two wires. Some of those NCV testers can pickup from a few inches away.
RKRider is offline   Reply With Quote
Old 07-02-2011, 09:50 PM   #13
how do i use the multimeter? lol sorry
Old 07-02-2011, 10:37 PM   #14
Black and red on your multimeter. Black goes to ground, red to the hot wire. Be sure black wire is to ground only, or once you touch the red to whichever is the hot wire, it will spark and could melt your leads. Seen it happen! Should get a voltage to see which is which on the meter.
J-Daddyshammer
Daddyshammer is offline   Reply With Quote
Old 07-03-2011, 01:28 PM   #15
Unhappy
i need some help with a light fitting and a dimmer switch!
Hi
I am replacing a light fitting and a dimmer switch
dimmer switch - black and red wires so from memory L1 and wavy line
light - spaghetti junction! 2 cables - each have green, red and black. i followed the instructions but when we switched the electricity back on the switch blew!
i put the old dimmer switch back on but we cant turn off the lights now. I've now removed the light but left the switch connected. We're not in the room at the moment so we dont need to use the light
help? where am i going wrong?
miniminx is offline   Reply With Quote
Bathroom Light Fixture with no junction box? shadowman Electrical 2 07-13-2010 06:54 AM
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 09:26 PM
Installing a new light fixture brokenhammer Electrical 1 01-10-2009 07:14 PM
Light fixture issue baustin Electrical 4 07-17-2007 04:01 AM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
