Hi I Need To Conduit A Set Of Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2011, 06:55 PM   #1
hi I need to conduit a set of outlets
high I need to make a set of conduit outlets for stage lighting . Basically they will be 3 boxes with 2 seperate circuts in each box and will be like an extension cord !!! My question is if I run 6 differant "hot wires" can I use the white common for all 6 outlets??
Thank You Carfixer
carfixer is offline   Reply With Quote
Old 12-11-2011, 07:03 PM   #2
Rewards Points: 6,652
It would be a MWBC (Multi-Wire Branch Circuit), if only two circuits. If this is in a commercial building, you are better to let the trades do it, since the city would frown upon a private individual not holding a license doing it.
Old 12-11-2011, 07:04 PM   #3
Rewards Points: 14,312
Your post makes little since. Conduit implies it will be soild piping between the outlets. If it's one line coming from one outlet why are you using separete power feed lines and trying to use a common white wire?
Old 12-11-2011, 07:04 PM   #4
Master Electrician
Rewards Points: 3,966
Sure, you can do anything you'd like. It would be totally unsafe and equally non code compliant, and especially stupid for a stage area.
brric is online now   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
gregzoll (12-11-2011)
Old 12-11-2011, 07:39 PM   #5
ok
this "stage" was using extension cords in ceiling. Now have to have outlets run in permanant condition. but need 6 seperate circuts. So what would be the best solution? Do I have to run seperate common wires for each circut?
Old 12-11-2011, 07:51 PM   #6
circut
The way it works is lights have plugs on them and the board has outlets on it. Small "jumpers will go from outlets to the board.
Old 12-11-2011, 07:53 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
It depends on what the service is to the building.
If it is single phase then you need one NEUTRAL per two hots. There are LOTS of other codes and rules to consider, such as conduit fill and derating, grounding, using two-pole breakers, and more.
Since you obviously do not know exactly what you are doing, and this is obviously not your home but a theater/stage where LOTS Of people will be gathering (making this setting a "place of assembly" with a lot of additional codes) why not stick to fixing cars and let the electrical people do this work????? You'll be MUCH better off in the long run I assure you.
Old 12-12-2011, 11:16 PM   #8
Do you need six circuits or six switched outlets ? Big difference. What lights are you using? Wattage?
Evstarr is offline   Reply With Quote
Old 12-13-2011, 03:43 PM   #9
Julius793's Avatar
Call an electrician so u will actually have a stage left
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 12-13-2011, 03:45 PM   #10
Julius793's Avatar
That's not true and can cause a FIRE!! The only time you can use one neutral for two hots is if the two hots are on different phases.
Old 12-13-2011, 04:14 PM   #11
Rewards Points: 506
Oh no...here it comes. Look out, Julius.
jlmran is offline   Reply With Quote
Old 12-13-2011, 04:23 PM   #12
Julius793's Avatar
Who should I look out for??
Old 12-13-2011, 04:24 PM   #13
Speedy knows the difference, but do you? To let you know Julius793, if the building is on three phase service, placing the two hots on different phases, could cause a fire among other problems. Rarely are these places Single phase systems.
Old 12-13-2011, 04:27 PM   #14
Rewards Points: 506
All the folks who will clarify your statement. And for those who will begin discussing phases, legs, degrees of separation, etc.
For example, what are the differences between MWBC's originating from single phase services vs three phase services?
Old 12-13-2011, 04:36 PM   #15
Julius793's Avatar
Three phase system u would do a mwbc like this, one hot to each phase and then just one neutral for the three hots
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 02:22 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 08:49 PM
Warm and Noisy Electrical Conduit Intravartolo Electrical 4 07-26-2010 01:46 AM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
