Old 06-08-2010, 02:07 PM   #1
Send a message via AIM to theatretch85
HGTV Holmes Homes
Saw an episode the other night, among other things they installed a new main circuit panel sideways. From what they were saying, the individual circuit cables cannnot come in through the top with the service entrance conductors because they can't rub against each other (they were as far as I could tell in their own knockouts). They indicated the wires needed to come in through the sides and not be anywhere near the service entrance conductors. So they installed a new panel sideways, with all the wires coming in through the side of the panel (now the top).
Did anyone else see this episode? I am very curious as to the validity of the reasons they had to put this panel in sideways.
theatretch85 is offline   Reply With Quote
Old 06-08-2010, 02:16 PM   #2
Master Electrician
HGTV Holmes Homes
I did not see the show but have heard of such installations. IMO it is ridiculous and a code violation unless all of the circuit breaker handles are pointing down when they are in the off position. I've also been told that show is produced in Canada so maybe some of the Canadian brothers know more about that situation.
brric is offline   Reply With Quote
Old 06-08-2010, 02:36 PM   #3
Licensed Pro
HGTV Holmes Homes
Sideways is a legal install in Canada.
Old 06-08-2010, 02:43 PM   #4
Knows everything but that
HGTV Holmes Homes
I saw that episode also. Now, I know extremely little about electrical code in the US and zero about it in Canada. However, it appeared to me that the wires in suspect were coming through a through the box in the same place the service wire was.
JakAHearts is offline   Reply With Quote
Old 06-08-2010, 04:13 PM   #5
HGTV Holmes Homes
Here in Canada panels are mounted either vertical or horizontal. Which ever way fits the best.
Any panels that I have ever seen have the breakers on one pole opposite to the others on the other pole.
So if the panel is mounted horizontally, the top pole breakers are moved down to energize the circuit, whereas the bottom breakers are moved upwards.
Of course, if mounted vertically, they are moved towards the centre to turn them on.
How you could have them all move up to to turn them on, I have no idea!
We use panels manufactured in the US and I doubt there is much difference in the panels shipped to Canada.
Old 06-08-2010, 04:19 PM   #6
Learning by Doing
Leah Frances's Avatar
HGTV Holmes Homes
Good to know the show's done in Canada - I just thought he was an idiot after the commercial I watched clearly stated X about code that is WRONG in the USA.
Sheesh - guess television isn't an authoritative source of information pertaining to code enforcement.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 06-08-2010, 04:19 PM   #7
HGTV Holmes Homes
They can come in any side except in the section provided for the service entrance cable.
Didn't your mother tell you to believe nothing that you hear and only half of what you see?
Old 06-08-2010, 04:43 PM   #8
HGTV Holmes Homes
Leah Frances - Just curious if you remember what code that might have been. I always like to know what's different up here then down there.
Troglodyte is offline   Reply With Quote
Old 06-08-2010, 05:28 PM   #9
Electrician
HGTV Holmes Homes
On any combination panel i have seen there is a barrier between where the service conductors are and the rest of the tub. If you came in the top you would have drill through the barrier which is a no no. With this setup it keeps homeowners away from the service conductor which there is no way to turn off.
darren is offline   Reply With Quote
Old 06-08-2010, 05:34 PM   #10
Xtreme DIY'r
HGTV Holmes Homes
I actually like the way they seperate the Main wires/lugs from the rest of the wires
If you watch the show for any length of time its pretty obvious most of the work they do is in Canada
They did do some work down South after Katrina, New Orleans area I think
Old 06-08-2010, 05:40 PM   #11
Sparkaholic
Send a message via Yahoo to sparks1up
HGTV Holmes Homes
Wildie;453057] How you could have them all move up to to turn them on, I have no idea!
You can't that is why it is a code violation in the US! You can't have a breaker handle facing down when on.
There are exceptions to this in some municipalities though. I have seen it done and pass an inspection in Coral Gables Florida where it replaced a panel that was originally installed that way in a space on a wall that would not let it be installed any other way and no place to relocate. But it is rare to see one installed that way!
I just did a job in a condominium where the original electrician saw fit to install all the Square-D meter stacks in all the meter rooms upside down because there were no openings in the top and all the apartments fed from the slab above. So all the main breakers are on in the down position....and he passed his inspection! Albeit 40-years ago
Still very rare to see!
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 06-08-2010, 06:20 PM   #12
HGTV Holmes Homes
My old roommate (master plumber) used to catch plumbing mistakes and code violations on those design shows all the time. Watching movies was always entertaining too. Between the plumber and the architect we always had a good laugh at some of the ridiculous crap hollywood tries to pass off.
cellophane is offline   Reply With Quote
Old 06-08-2010, 06:47 PM   #13
HGTV Holmes Homes
The biggest mystery about that show is how he ever made it as a General Contractor.
I picture GC1 bid = $1,650
GC2 = $2,100
and Holmes = $23,000, "but it'll be done right"
forresth is offline   Reply With Quote
Old 06-08-2010, 06:53 PM   #14
nap
You talking to me?
nap's Avatar
HGTV Holmes Homes
GC2 = $2,100
look at it this way:
GC1 bid= $1650
GC2= $2100
Not having to have the work redone 3 times and pay the cost of an attorney to sue either of the other 2 contractors:
PRICELESS!!
Old 06-08-2010, 07:09 PM   #15
HGTV Holmes Homes
GC2 = $2,100
Where the money comes for his renos. is a mystery? Mike never works with what he's got! Its rip and tear the whole nine yards.
I betcha that they look over many, many properties before they find one that the sponsor will be prepared to finance.
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
Fire Sprinkler systems in new homes majakdragon Off Topic 14 01-23-2009 04:41 PM
Love old homes Mikey General Discussion 6 02-05-2007 06:28 PM
