Heyward Pool Pump 1 1/2 Hp - Electrical - DIY Chatroom Home Improvement Forum
Old 06-12-2011, 07:26 PM   #1
Heyward pool pump 1 1/2 hp
Pump was leaking needed to replace the seal. Did that put it back together and pump started smoking. It looked like the v piece on the back of the shaft was moving slowly and then breaker kicked off electricity. At first the v piece got stuck on piece connected to shaft and was smoking shut it down try again that's what cause the breaker to go off. Any ideas on this
DEBBY is offline   Reply With Quote
Old 06-12-2011, 08:04 PM   #2
Electrical Contractor
kbsparky's Avatar
Motors don't run on electricity. They run on smoke. The electricity is only needed to keep the smoke in. Once the smoke gets out, the motor is no good....
Time for a new pump.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
electures (06-13-2011)
Old 06-12-2011, 08:56 PM   #3
just a tool guy
mickey cassiba's Avatar
Thanks...I been trying to tell folks that for years!
Mickey
One of these hammers will fix it.
mickey cassiba is offline   Reply With Quote
Old 06-13-2011, 08:09 AM   #4
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Sounds like the seal leaked and water got into the motor. Fried!
electures is offline   Reply With Quote
Old 06-13-2011, 10:59 AM   #5
Rewards Points: 236
That's why it's not economical to attempt repair on small pump motors. Most people never get them back together. At least the OP got to see the smoke. Most never get that far.
How to find out why your pool pump is not fully priming tripflex How To Guides 8 07-15-2015 05:15 AM
Pool pump, cleaner, light wiring issues tulsajeep Electrical 4 06-05-2011 06:56 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
Pool Pump Wiring mpdive Electrical 17 06-15-2008 07:30 PM
Pool Care Guide scottiedog Landscaping & Lawn Care 16 06-07-2008 08:41 PM
