Here Is An Interesting/odd Electrical Issue.. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-31-2012, 09:11 PM   #16
hummer4x4guy's Avatar
Here is a shot of the wires on the new switch.
Here is an interesting/odd electrical issue..-image-2810481200.jpg
hummer4x4guy is offline   Reply With Quote
Old 07-31-2012, 09:21 PM   #17
"So I Re-Wired It"
MisterZ's Avatar
i found this video which supports your style installation. no neutral needed
http://youtu.be/3aay7IFY6-g
MisterZ is offline   Reply With Quote
The Following User Says Thank You to MisterZ For This Useful Post:
hummer4x4guy (07-31-2012)
Old 07-31-2012, 09:26 PM   #18
Missouri Bound's Avatar
Originally Posted by MisterZ View Post
originally i thought this too, but he describes the wires as follows:
Not seeing a Neutral there... maybe he left it out of the description
Nope, you are correct. I looked at the spec sheet. Apparently the ground is a necessary connection though. Perhaps he can get that from the box. No other reason it shouldn't work.
Do you want it your way or the right way?
Old 07-31-2012, 09:32 PM   #19
Miss B.. I have no ground wire.. the box just sorta sits in the wall. I decided ill run the rest of my 14/2 wire and put it all on its own breaker. That should be good. I believe. Ill let ya know what happens tomorrow.
Old 07-31-2012, 09:38 PM   #20
"So I Re-Wired It"
MisterZ's Avatar
good luck M8
Old 07-31-2012, 10:16 PM   #21
Rewards Points: 506
Originally Posted by hummer4x4guy
When I flip switch on and turn on the light I get 00.0
This is normal if your measuring across the switch terminals.
jlmran is offline   Reply With Quote
Old 08-01-2012, 11:40 AM   #22
Mran thx for the conformation on the reading.
Here is where I am now. Wire is run from breaker but not hooked up. Im at the sensor location now and wanted to make sure I had this wired properly. The line comig into the box on the left is from the breaker. The right side is going out to the lights after its passed through the sensor.
I followed the instructions on wiring it as best as possible.
Here is an interesting/odd electrical issue..-image-3817425518.jpg
Old 08-01-2012, 01:44 PM   #23
Success!!!!
I have one of the two ceiling lights installed and wired and the motion switch works great. Only wish it had a few more options for a shorter time setting once no motion is sensed. But for now I'll keep it in test mode which is 5 seconds. Tomorrow I'll wire up the final light which is over washer n dryer and clean up the next in a week or so haha.
Thanks to you all for helping along the way.
Old 08-01-2012, 04:18 PM   #24
"So I Re-Wired It"
MisterZ's Avatar
just want to make sure.... where the first light box is, there were other wires coming into that box.
originally there was power going to this box, did you eliminate that power source??
just be careful not to hook up something unless you know where it goes.
Old 08-01-2012, 04:29 PM   #25
Yup those are all dead now and ive not hooked anything new to at old wires. I just now got the 2nd light installed and all works just perfect!
Old 08-01-2012, 05:10 PM   #26
"So I Re-Wired It"
MisterZ's Avatar
excellent!! good job M8.
if you neeed any other assistance, we'll be here
Old 08-01-2012, 05:27 PM   #27
Thanks Z and everyone else.
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Electrical issue - 240V - Water Heater emoore Electrical 9 09-30-2009 01:45 PM
Unusual electrical issue LosLobo Electrical 7 11-10-2008 01:44 PM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
Electrical issue w/running Exhaust Fan/Light off GFI Exhaust Fan Electrical 1 03-20-2004 05:07 PM
