Help Wiring Up An Old Craftsman Motor - Electrical - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By micromind
  • 1 Post By diy888
Old 11-16-2012, 02:40 PM   #1
Rewards Points: 248
help wiring up an old Craftsman motor
The cloth insulated wires inside were all frayed and exposing bare metal at their bends, so I clipped them above the fray points and then spliced new wires to them using compression splices and heatshrink insulation. But the pictures I took to help me rewire everything back up aren't as clear as I thought they'd be. And some time has elapsed since I started the project, so memory does not serve.
The motor has a start capacitor.
I'd be grateful if someone could tell me how the connections go. Wires A, B, C, D, and E are emerging from the windings. I've drilled and tapped the base for the ground wire.
diy888 is offline   Reply With Quote
Old 11-16-2012, 07:36 PM   #2
joed's Avatar
Rewards Points: 13,764
No way to know from what you have provided. You will need to figure out what each wire goes to then wire it like one of the drawing here..
http://www.electrical-contractor.net...e=1#Post178599
Old 11-16-2012, 08:17 PM   #3
Idiot Emeritus
Rewards Points: 1,492
A bit more info is needed;
1) Do you have a multimeter that has an Ohms (resistance) scale?
2) Is R and S the capacitor?
3) Is G and F the centrifugal start switch?
4) Are you absolutely positive there are 5 wires coming out of the stator (windings) and not 6?
5) What is X and Y?
It'll take a bit of trial and error, but I think we can make this work.
Rob
Kjn4685 likes this.
micromind is offline   Reply With Quote
The Following User Says Thank You to micromind For This Useful Post:
Kjn4685 (12-28-2016)
Old 11-17-2012, 06:24 AM   #4
Rewards Points: 248
5) What is X and Y?
Rob
Thanks for the help.
I will buy a multimeter. I watched several videos on how to use them last night, and could test wire pair combinations for continuity and resistance, if you told me which combinations you needed.
Confirmed, only 5 wires emerge from the stator, at the locations indicated.
X an Y is the wiring terminal bloc.
R and S is the overheat reset switch.
F and G is the centrifugal start switch.
Capacitor is not shown. As long as I end up knowing which wires to bring out to the capacitor, I do remember how to attach the spade connectors there:
1== 3==
o o
2== 4==
(1+3 or 1+4 or 2+3 or 2+4).
I am attaching the clearest pictures of the wiring when I first opened the motor up. It looks to me as though
MAINS neutral goes to centrifugal switch F.
MAINS hot goes to reset switch S.
E goes to capacitor (not shown).
D goes to ?
A goes to terminal block X.
B goes to terminal block Y.
C goes to ?
help wiring up an old Craftsman motor-dscn2311.jpg   help wiring up an old Craftsman motor-dscn2303.jpg   help wiring up an old Craftsman motor-dscn2306.jpg
Kjn4685 likes this.
The Following User Says Thank You to diy888 For This Useful Post:
Old 11-17-2012, 02:04 PM   #5
Rewards Points: 248
Woohoo! Found a pencil sketch I'd made of the wires. I'm not the fool I thought I was, just an electrical ignoramus with a bad memory.
Craftsman Garage Door Opener Motor Not Working, Clicking Sound hammerlane General DIY Discussions 30 04-17-2017 01:51 PM
Heat pump motor wiring 70sixspeed Electrical 2 10-29-2011 12:21 PM
Blower Motor Wiring reversed? HVACMac HVAC 60 08-30-2011 02:10 PM
Wiring a Haldex pump and motor on a 2 post lift 69malibu Electrical 9 08-17-2011 12:00 AM
Blower Motor quit, changed wiring now working? wsjr1 HVAC 20 01-10-2010 06:01 PM
