Old 12-28-2009, 07:51 PM   #1
help wiring up computer fan with wall outlet plug
Hello, need a little advice on a project Im working on.
Without the details, I need to be able to plug a computer's cooling fan directly into a wall socket. I got the computer fan which has its own motor and lead wires. Here are the specs for it: Rated voltage=12VDC, Voltage range=10.2-13.8VDC, Rated current=.32Amp max, Rated power=3.84watts max.
Is there a way I can wire it up so I can plug it into a wall socket? What size wire should be used? Any help on this is great. Thanks!
marstang50 is offline   Reply With Quote
Old 12-28-2009, 08:21 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
You will need a DC transformer, which you can get from RadioShack. They have the parts avail to soldier & Heat Shrink the connection.
Old 12-28-2009, 08:26 PM   #3
Why don't you just use a 120V fan?
jerryh3 is offline   Reply With Quote
Old 12-28-2009, 08:54 PM   #4
I need a fan that has a low airflow and when looking around on the net, the only thing that seemed like it would work was a CPU cooling fan. What Im trying to do is run a 4" duct with an inline fan from a room in my house that has a fireplace, to another part of the house because the heat does not move from the room easily. A strong fan would offset the draft for the fireplace. It just seemed that the cpu fan would fit well with the duct work (with some rigging) and wouldnt be too powerful. Just need to be able to move the air a little. Ive seen the inline booster fans for ducts but too much boost.
Old 12-28-2009, 09:21 PM   #5
joed's Avatar
A small 12 volt wall wart will work.
An old PC power supply although bulky will also work.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 12-28-2009, 09:27 PM   #6
gregzoll's Avatar
Instead of doing this, I would call in a HVAC engineer and see if they have a solution that will work. Sometimes the cheapest route is not the best route.
Old 12-28-2009, 10:08 PM   #7
joed's Avatar
A fan would not offset the draft unless it blowing the air out of the structure. Blowing air around inside the same structure should not cause a back draft.
Old 12-28-2009, 10:19 PM   #8
Xtreme DIY'r
A PC fan won't push that much air, you need more cfm's
I sometimes use a big fan to push air around the house
It has no effect on the fireplace draft
Old 12-28-2009, 11:28 PM   #9
I would sugest you get an inline duct fan. It's made for this purpose.
hayewe farm is offline   Reply With Quote
Old 12-29-2009, 06:07 AM   #10
thanks for the input. I think I will try the inline duct fan. Seems a bit much to try to rig up this cpu fan. I will post back how things go.
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 01:14 AM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 03:06 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Is it a hazard to plug a surge protector into an ungrounded GFI outlet? CuriousWithQuestions Electrical 7 02-01-2008 10:04 PM
changing a range outlet or plug marty7 Electrical 9 12-17-2007 11:11 PM
