Help With Wiring Two Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2009, 09:50 PM   #1
Help with wiring two lights
I need some help. I am trying to make sure I wire two motion lights to one switch. I was planning on using 12-2 wiring. Could someone please help me by providing the direction as I want to make sure I do it correctly.
kjdement is offline   Reply With Quote
Old 09-24-2009, 12:04 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Do you want the 2 lights to come on at the same time, or does it matter?
From switch to first light, then from light to next light.
Connect all whites together and the all the blacks together.
I assume that the motion sensors are already wired to the light sockets.
jbfan is online now   Reply With Quote
Old 09-24-2009, 09:41 PM   #3
Yes I want both lights to come on at the same time. Right now all I have is the wiring to a switch. What I am doing is taking the light that was currently operated by the switch and taking that light out and putting in two motion lights. So nothing is wired yet.
Thank you for your help.
Old 09-25-2009, 08:38 AM   #4
joed's Avatar
Rewards Points: 12,018
Connect the black and white from your existing fixture to the new fixture. Run a new cable from the first fixture to the second fixture and connect the wires matching the colours.
Wiring multiple lights off of an existing light?? n00b Electrical 22 06-21-2009 05:37 PM
Wiring up an outside set of motion sensing lights airdaleairdale Electrical 1 06-11-2009 09:35 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 01:39 PM
Wiring for external lights and outlets MikeinBurien Electrical 4 12-05-2005 01:16 AM
