Help Wiring A Switch And Plug To A 240v Single Phasemotor - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2012, 09:45 PM   #1
Help wiring a switch and plug to a 240v single phasemotor
I bought a tool from somebody without a plug and thought I would take a chance on it. I noticed a big problem taking the cover off. It looks like the white and green are reversed. There is no plug on the other side and plan on going to pick up a 240v plug. (the side wired up is going to the motor, the size with a loose wire goes to the plug).
In the switch compartment, if I hook up the green to be in line with the red wire, should I then match the white wire with the longer round prong on the plug. I am pretty sure if I hook up the 240v lines to the flat prongs it doesn't matter the order. It is also going into a residential 240 outlet that is wired correctly.
would that be correct or would there be a better way of doing it. Any information would help me out a lot.
Also is there any wrong way to incorrectly hook up the motor where it smokes or fries? a 2hp 240v motor is a bit pricy for a new one.
da_man is offline   Reply With Quote
Old 10-31-2012, 09:49 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You are correct in your thinking. Hook up the white wire to = the red wire. Connect the green to the ground terminal, then attach the 240V cord end. The order of the phases does not matter for a single phase power supply.
Old 10-31-2012, 09:52 PM   #3
thanks, but what would happen if the green and white wires were reversed and plugged in? would it work. also would there be anyway I can destroy the motor?
Old 10-31-2012, 09:56 PM   #4
k_buz's Avatar
If left the motor starter as is (with the white hooked up to ground and green to 120V) and wired the cord end with black and white to be the hot wires (green to ground) you would energize anything metal on the tool or that the tool is touching.
If you left the motor starter as is, and wired the cord end with black and green being your hot wires (white as your ground) the tool would work just fine. Although the NEC requires the ground to be green, green with yellow stripe, or bare.
Old 10-31-2012, 10:59 PM   #5
If left as is the 240v motor would get 120v and either trip the breaker or smoke the motor. Likely trip the breaker after it hummed for a short bit moving either slow or not at all.
If the tool was grounded out to something else that had a direct path back to the bond in the panel the breaker would trip instantly.
Marc05 is offline   Reply With Quote
Old 11-01-2012, 06:23 PM   #6
I wired up the motor for the tool and it works great. Thanks for your help.
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 12:36 AM
wiring a circuit plug controlled by a switch shannacat123 Electrical 1 05-22-2011 09:36 PM
How do I provide power to a plug when changing single pole 3 wire to 3-way switch Morris12 Electrical 4 01-05-2011 08:41 PM
electrical plug and switch Linda Patterson Electrical 3 05-10-2010 06:55 PM
wiring switch to gfci plug wendl Electrical 5 04-05-2010 09:02 PM
