Help Wiring A Single Pole Indicator Light - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2013, 11:25 AM   #1
help wiring a single pole indicator light
I am trying to wire a small 110v indicator bulb on the switch side of a single pole thermostat ;so i can see when it is powering a heater. the trick is I dont want it to be directly in line as to stop the heater if the bulb were to burn out. Any Ideas would be appreciated.
smittty is offline   Reply With Quote
Old 01-07-2013, 11:54 AM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,938
The indicator goes in parallel with the heater, not in series. The heater wouldn't work at all if you put it in series.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
smittty (01-07-2013)
Old 01-07-2013, 12:00 PM   #3
You can buy a switch with a built in indicator light! Would save a bit on the work involved.
The Following User Says Thank You to Wildie For This Useful Post:
Old 01-07-2013, 04:48 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,350
One side of the indicator light goes to the hot wire to element,
The other wire of the indicator light goes to neutral.
This puts it in parrallel not series !
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Single Pole Breaker VS. Quad Breaker Livewire78 Electrical 37 11-28-2012 08:26 AM
Fan Switch from single pole to . . . Smudgeboss Electrical 1 04-27-2012 08:27 PM
Double 15 amp single pole mmacnz Electrical 6 04-17-2011 09:11 PM
Double pole breaker used as single pole WonderingOne Electrical 11 11-30-2010 12:37 AM
single gang single pole switch on fan fabian Electrical 14 03-05-2009 01:11 AM
