-   -   help wiring a single pole indicator light (http://www.diychatroom.com/f18/help-wiring-single-pole-indicator-light-168474/)
smittty 01-07-2013 11:25 AM
I am trying to wire a small 110v indicator bulb on the switch side of a single pole thermostat ;so i can see when it is powering a heater. the trick is I dont want it to be directly in line as to stop the heater if the bulb were to burn out. Any Ideas would be appreciated.:(
mpoulton 01-07-2013 11:54 AM
The indicator goes in parallel with the heater, not in series. The heater wouldn't work at all if you put it in series.
Wildie 01-07-2013 12:00 PM
You can buy a switch with a built in indicator light! Would save a bit on the work involved.
dmxtothemax 01-07-2013 04:48 PM
One side of the indicator light goes to the hot wire to element,
The other wire of the indicator light goes to neutral.
This puts it in parrallel not series !
