Help With Wiring In Shed - Electrical - DIY Chatroom Home Improvement Forum
Old 06-25-2008, 10:52 AM   #1
Rewards Points: 152
Help with wiring in shed
Hello All,
I ran some conduit into my shed from the panel in my basement. I have that going into a junction box. On the other side of the junction box, I have conduit running back out of the shed to a pond. I will have a GFI rec. there and I would want it switched in the shed.
I also want a light that is switched in the shed and then I will put in a GFI rec in the shed.
What is the best way to wire this?
sandyman720 is offline   Reply With Quote
Old 06-25-2008, 11:11 AM   #2
Rewards Points: 246
What size wire did you pull, how many and is it in PVC?
It looks like you are just installing a branch circuit.
Install a GFCI breaker inside the basement panel or install one at the box you installed at the shed. Feed your shed light and switch off the load side of the GFCI receptacle if you use one. Any subsequent circuit extensions can be protected by this GFCI receptacle. It may be easier to use a GFCI breaker as it will allow for plenty room in your box and protect the buried conductors.
Then just run another conduit or UF cable to the pond. Make sure it is connected to either the GFCI breaker or receptacle. And most important is that you have included a ground (EGC) wire in your pull. If not you need one. Have fun.......John
gounding requirements in shed bmcmahon Electrical 2 06-17-2008 09:24 AM
Shed Wiring bcdal Electrical 12 03-26-2008 04:51 PM
Wiring a shed ocoee Electrical 3 06-05-2007 04:25 AM
Subpanel to Shed - Check my plan NateHanson Electrical 9 04-26-2007 09:56 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
