Help With Wiring Project - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 02:08 AM   #1
Help with wiring project
Hi all,
Having some amount of difficulty trying to accomplish this small task. i am not an electrical guy but figure with some help this is not too hard to do.
i am trying to wire 4 - 120v receptacles (inside a small metal box) to 4 lighted rocker switches so that i have 4 controls for 4 sets of lighting sources.
Basically i want this box to be able to plug into the wall(ac) and give me 4 seperate outs to power 4 strobe lights. the rocker switches are of course to turn each strobe on or off individually and independant of each other.
Also i wouldnt mind adding a master switch to power the whole box down.
Any thoughts on how to wire this up? should i have any fuses or anything in there for protection etc etc.
im quite new to trying this so any help would be greatly appreciated.
thx
Colin
csmart is offline   Reply With Quote
Old 03-08-2010, 05:56 AM   #2
You can gang metal boxes together to form one box to hold everything. Standard receptacles have a brass metal connector that connects each outlet together. Break that off and you have an individual outlet. Two receptacles will give you 4 individual outlets. Multiple switches are also available. How much power do these strobes draw?? That will be the key as to what is required.
Old 03-08-2010, 10:59 AM   #3
Thank you for replying. I have a small metal box already from a previous piece of equipment that fit the need perfectly. I think the max draw on the first 2 rockers are maybe 100watts and number three would be around 125, the fourth one is 250 though, its the big massive strobe that all the kids really like
should i install a circuit breaker or something in case of overloads or spikes as well??
thx,
Colin
Old 03-08-2010, 11:40 AM   #4
Master Electrician
Rewards Points: 3,820
Your figures add up to 575 watts. That should work on almost any circuit unless it is heavily loaded. I see no reason for additional fusing within the box itself.
brric is offline   Reply With Quote
Old 03-08-2010, 11:41 AM   #5
If this is being used outside make sure it is GFCI protected
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Smokehouse Wiring project questions - 220V Beck74 Electrical 5 01-03-2010 11:22 AM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 02:06 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
