Help Wiring A Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 07:58 PM   #1
help wiring a panel
hi all , i have a garage that i am replaceing the pan el just so it's updated a little for future use and cause i got it free.
anyways
from my house i have 14/3 wire going to my panel in the garage , i want to change this panel with a new one , however i am unsure where to place the red and black wire commig from the house on this new panel\
here is a picture of the old and new panel . , in the house the 14/3 is fconnected to 2 15amp breakers i thinkl.
old panel http://dl.dropbox.com/u/34800164/Panel%20Old.jpg
new panel i want to use http://dl.dropbox.com/u/34800164/Panel%20New.JPG
any pointers greatlly appreciated !
Mike
ex-28 is offline   Reply With Quote
Old 01-26-2012, 08:08 PM   #2
jproffer's Avatar
Rewards Points: 706
First thing I would do is pull bigger conductors if it's possible. 14/3 isn't going to give you very much capacity.
However, to answer what you actually asked ......
The red and black (hots) go to the center, where the black plastic section is...ultimately connect to the buss bars. It looks like they maybe connect to the 2 screws at the very top of the picture. Black/Red don't matter where they go...pick one screw for each.
The white conductor (neutral) goes into the bar at the bottom of the picture.
Get rid of all the old scraps of wire first ...but where the white scraps are....that's the neutral bar.
jproffer is online now   Reply With Quote
The Following User Says Thank You to jproffer For This Useful Post:
plummen (01-26-2012)
Old 01-26-2012, 08:09 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by ex-28 View Post
anyways... from my house i have 14/3 wire going to my panel in the garage
OK. Pointer is to start over and use substantially heavier wire...
or to leave sleeping dogs to lie.
Old 01-26-2012, 08:14 PM   #4
1 red to one and 1 black to the other ?
1 other thing , what is the big one at the bottom for ?
oops thats where the white goes i see that now
thanks agian , also on this setup , i should only run 2 15amp breakers max ?
Old 01-26-2012, 08:25 PM   #5
jproffer's Avatar
Rewards Points: 706
You can run as many of any size breakers you want, but you're only going to get 15A max. from the house....after you draw beyond that, it will trip at some point.
BTW, just because it hasn't tripped yet, doesn't mean it's not drawing more than 15A. Breakers trip on a time/amperage curve (unless it's tripping because of a short circuit). A 15A breaker will pass 16A for a certain amount of time, but will eventually trip...the same breaker will pass 20A for less time before it trips.
Old 01-26-2012, 08:28 PM   #6
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Doing this just don't make any sense at all. You are just going to replace a perfectly good working device with something that you will never use unless you decide to increase the wires size going to the garage.
rrolleston is offline   Reply With Quote
Old 01-26-2012, 08:31 PM   #7
jproffer's Avatar
Rewards Points: 706
LOL, I agree.
He asked though...I try (sometimes fail, but I do try, lol) not to throw too many of my own opinions onto someone else. If he wants to do this, who are we to tell him he can't
Old 01-26-2012, 08:38 PM   #8
only reason i am replacing the panel is cause i am putting in a new garage door and all the wireing runs roght above the door so i have to remove all the wires except the 3 comming in to the garage , i;'m that far already and have the panel laying aorund so i might as well swap it out , that and original old panel cover is damaged and mounted upside down.
Old 01-26-2012, 08:46 PM   #9
rrolleston's Avatar
True. But one thing is the new panel looks much cooler than the old one. I do have one suggestion since this panel does not come with a main breaker I would feed the panel through two 15 amp breakers that way you have a way to disconnect power going to the buss when you need to without going to the house
Old 01-26-2012, 08:49 PM   #10
Still waste time and no gain. I did not to be the first to coment neg, you have no clue what you are doing.
Hardway is offline   Reply With Quote
Old 01-26-2012, 08:51 PM   #11
jproffer's Avatar
Rewards Points: 706
That's a good idea
Another thing I just noticed is:
in the house the 14/3 is connected to 2 15amp breakers i think.
If that's the case, the 2 breakers either need to have a handle tie or just change it out for a 2 pole breaker.
Old 01-26-2012, 08:56 PM   #12
That's a good idea
thats where i;m kind of lost , i have regual 15 amp breakers and 15 amp breakers as shown in the picture where the handles are joined , not sure what to use or why there made this way , or what side of the panel to plug the breakers into , all on 1 side on keep them equal
Old 01-26-2012, 09:01 PM   #13
jproffer's Avatar
Rewards Points: 706
The one that's on the new panel looks like a tandem breaker. That is NOT a 2 pole breaker....and that's not what I meant anyway. The 2 breakers feeding the garage panel (in the house) need to be tied together (or made together...2 pole breaker).
With 15A feed, it don't really matter where you put them...balancing the load isn't going to be a problem .
ex-28 (01-26-2012)
Old 01-26-2012, 11:49 PM   #14
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You do realize that is a old stab-lok panel ... yes?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 01-26-2012, 11:54 PM   #15
Both are older panels yaya
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 10:49 AM
wiring sub panel right next to main panel bill423 Electrical 4 05-14-2011 08:17 PM
Wiring a sub panel to another sub panel Uncle Wayne Electrical 25 02-08-2011 09:50 AM
Sub panel wiring question mntnvew Electrical 13 03-02-2009 11:28 AM
