Help Wiring New Fixture Onto Three Way? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2013, 03:27 PM   #1
help wiring new fixture onto three way?
Hello,
I am trying to replace an older cheap fixture that is wired to a 3 way switch, I think.
the new fixture I am using is simple (1 black, 1 white, 1 ground).
unfortunately when I unscrewed the old wall fixture, it had 2 white, 2 black, and a ground curled up in the back of the box.
the old fixture has both whites attached to one side with 2 green screws (one for each wire) and then the 2 blacks on the other side with again 2 black screws for each wire.
I don't have the slightest idea of how to wire the 2 white 2 black and unused ground to the new fixture. I couldn't find anything comparable on the older posts on the web.
thanks for any/all help.
tfonz
tfonz is offline   Reply With Quote
Old 09-01-2013, 04:16 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
It's tfonz, ayyyyyyyy
wirenut1110 is offline   Reply With Quote
Old 09-01-2013, 06:02 PM   #3
I'll bite. I don't understand the white wires and green screws, or black wires with black screws.
Are you saying the fixture had two white and two black wires, or are you talking about the house wiring?
RoyalAcresRod is offline   Reply With Quote
Old 09-01-2013, 06:07 PM   #4
Rewards Points: 150
How many lights are on that circuit. Could be powering more than one light
romex1220 is offline   Reply With Quote
Old 09-02-2013, 01:43 PM   #5
hope to add some clarity
wish it were easier to post pics.
I hope this works..
top pic is the new fixture
bottom pic is the old one with strange? (to me) wiring.
there are 2 switches that operate this one light... making this a one fixture 3 way switch, right?
i'll send a pic of the box behind the outlet next.
thanks again!
help wiring new fixture onto three way?-wiring-1.jpg   help wiring new fixture onto three way?-wiring-3.jpg
Old 09-02-2013, 01:48 PM   #6
here's the box behind the fixture
here is the view behind the original wall fixture
thanks again!!!
Old 09-02-2013, 02:05 PM   #7
The fact that your circuit is controlled by a 3-way switch is irrelevant.
Connect the blacks together, the whites together, and ensure the ground wire is attached to the ground wire in the box.
You should be good to go
Old 09-03-2013, 03:26 PM   #8
it worked
thanks royalacres
it worked just fine.
best to all who chimed in,
tfonz
Ceiling light fixture wiring eveready Electrical 2 03-10-2013 10:55 AM
Adding a light fixture wiring question draconius Electrical 20 03-01-2013 10:56 PM
Hard Wiring vanity light fixture into outlet? qwiksilvertrav Electrical 16 02-24-2013 01:16 PM
Wiring fan and separate light fixture problems wallyboard Electrical 1 06-24-2011 12:10 PM
light fixture wiring jasjks Electrical 4 11-29-2006 02:51 PM
