Help With Wiring Multi-bulb Lamp - Electrical - DIY Chatroom Home Improvement Forum
Old 02-23-2017, 12:56 PM   #1
Rewards Points: 6
Help with wiring multi-bulb lamp
Thanks in advance. I'm just trying to wire a table lamp with multiple bulbs and I have a few questions. I've wired chandeliers several times but I always clustered the wires - this won't work on this lamp. I've attached a diagram. I believe I've drawn a parallel circuit but not sure. Couple questions: the sockets have leads attached which are (I believe) SPT-1 18 gauge AWM rated at 105 Celsius. I'll use an SPT-2 cord for the power supply up to the first set of wire nuts. If each of the connections are with wire nuts (the squares on the diagram) does it matter what size wire I use internally between them? Stick with AWM or SPT-1, does it matter? Bulbs will be either 25 watt or 40 watt max so am I correct that 4x25 will draw 0.83 amps and 4x40 will draw 1.33? Everything look okay for that? Any other concerns about this design? Thanks again!!
wjcmpbll is offline   Reply With Quote
Old 02-23-2017, 01:10 PM   #2
Rewards Points: 1,280
Re: Help with wiring multi-bulb lamp
One time posters are not allowed to include graphics.
Post a few more times, and try again.
ED
de-nagorg is offline   Reply With Quote
Old 02-23-2017, 01:14 PM   #3
Rewards Points: 6
Okay. Thanks. Was wondering why it wasn't visible.
Old 02-23-2017, 01:14 PM   #4
Rewards Points: 6
Here's the diagram: https://drive.google.com/open?id=0B9...XFFRXlETzU3dzA
Old 02-23-2017, 01:24 PM   #5
Use wiring equal to , or larger than what is on the sockets.
Never undersized, because the undersized wire will heat up and probably catch fire.
ED
Tags
circuits , lamp , multiple lights , socket , wiring diagram
rapid lamp (bulb) failures aribert Electrical 9 01-20-2016 07:58 AM
Simple question about lamp wiring rcaver Electrical 2 01-05-2016 04:11 PM
Knob & Tube Wiring? cbzdel Electrical 8 08-17-2012 07:33 AM
wiring for an old fluorescent desk lamp wilson1764 Electrical 0 11-26-2010 08:18 PM
help with lamp wiring please profondorosso75 General DIY Discussions 1 11-07-2010 07:46 PM
