Old 02-15-2009, 07:51 PM   #1
Help wiring motor to kickspace heater
I am replacing an Embassy Industries HAV-88 kickspace heater motor and blower. When I removed the defunct blower/motor, there were two wires coming from the motor to the electrical box. I just got the replacement, and there are now 3 wires, but I still only have 2 wires in the electrical box. I tried to find some specs from the manufacturer A.O. Smith but I have been unable to find anything so far. Does anyone know what these three wires (red, black, white) are for? I assume two powers and a ground but not sure. The website below has all the information:
http://www.hvffl.com/images/hav88/hav88.html
Thanks in advance.
acurrier is offline   Reply With Quote
Old 02-15-2009, 08:04 PM   #2
joed's Avatar
Can't find that motor in the link provided. Is it a 2 speed motor where the old one was one speed?
it's .57 amps not 57 amps.
Old 02-15-2009, 08:12 PM   #3
Thanks for the amperage clarification. Maybe I didn't see the decimal on the case. The photos are there, not sure why you're not able to see them. Here are the direct links:
www.hvffl.com/images/hav88/New motor 001.jpg
www.hvffl.com/images/hav88/New motor 002.jpg
www.hvffl.com/images/hav88/New motor 003.jpg
www.hvffl.com/images/hav88/New motor 004.jpg
The motor I ordered should be the same one as the one I replaced. I had it special ordered and was told it was the motor for an HAV-88.
Old 02-15-2009, 08:21 PM   #4
the Musigician
DangerMouse's Avatar
looks like a two speed to me.... test it and see.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 02-15-2009, 08:22 PM   #5
joed's Avatar
The photos are there. I see them. The link provided to A.O.Smith does not have info for that model of motor. Did any paperwork come with the motor? I am thinking this could be a two speed motor and the old one was one speed.
White to black one speed.
White to red second speed.
Old 02-15-2009, 08:28 PM   #6
Thanks for the responses. I cannot find this exact model on the A.O. website anywhere due to their poor search capabilities. So it sounds like I have a two speed motor. Dangermouse: how do I test it? Joed: can I just ignore one of the wires and hook it up to the box?
Old 02-15-2009, 08:30 PM   #7
the Musigician
just like that... what he said, tnkx joed
DM
Old 02-15-2009, 08:37 PM   #8
There are 3 wires on the motor, black, red, and white. There are two wires in the electrical box, both black. Which goes to which?
Old 02-15-2009, 10:35 PM   #9
Electrical Contractor
wirenut1110's Avatar
Send a message via AIM to wirenut1110
You'll need to test those blacks to see which one is hot. Connect the hot to black or red, depending which speed you want (low speed is 60 cfm, high speed is 103 cfm) and the other to white.
Do you have just an on/off or high/low/off switch?
You're old one was apparently single speed and that's why you're short a wire.
wirenut1110 is offline   Reply With Quote
Old 02-15-2009, 10:43 PM   #10
Thanks for the info wirenut. The model I have just hooks up and turns on when the heat turns on - there's no switches. This is an old model that was put in when the house was built (I'm guessing) in 1988. Newer versions of this type of heater do have a hi/lo switch, so even though I was told this was for the HAV-88, it appears I got one for the HAV-88-2.
I will test the blacks and find the hot one. Does it matter which speed? I guess low would do the trick. Which color is low, and which is high - can you tell? And what do I do with the "extra" one - just let it sit?
Old 02-16-2009, 09:00 AM   #11
According to an electrician friend of my father's, the hot wire is white, low speed is red, high speed is black. If anyone thinks otherwise, please let me know. I will be doing some trial and error this afternoon. Thanks for the responses.
Old 02-16-2009, 09:11 AM   #12
the Musigician
there is a specs pdf on your link at the bottom. have you looked at that? it should answer the question for you.
my crappy pdf reader didn't open it, thanks again, adobe, for another 'new' format....
i should think white is white and r/b are hot, black-high speed, red-low, but maybe i'm thinking bassackwards again?
DM
Old 02-16-2009, 09:15 AM   #13
It's a 120 volt motor so the white would be the neutral and red/black would be hots, depending on the speed.
Hook up the red and white, turn it on and make note of the speed, then disconnect the red and hook the black up and make note of the speed. You'll be able to tell which one was low/high. Yes just cap the one you don't use. Since it has an insulated spade connector, you could just put some tape over it.
Old 02-16-2009, 09:20 AM   #14
the Musigician
tnkx wirenut! i thought so, but my coffee level is still low.....
DM
Old 02-16-2009, 09:37 AM   #15
He may be thinking that this is a switch box using a 3 wire cable where the switch would be fed with the white and black/red are switch legs.
This isn't the case.
Kickspace Heater. Clutchcargo HVAC 1 11-22-2008 02:03 PM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 04:32 AM
Wiring tankless water heater TheBossQ Electrical 4 07-11-2008 01:05 PM
Piping a kickspace heater on its own zone Mike Warner HVAC 5 05-12-2008 12:51 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 10:40 PM
