Help Wiring Four Switches (Pics Included) - Electrical - DIY Chatroom Home Improvement Forum
Old 08-31-2013, 12:52 PM   #1
Hi all,
Below are a few pictures for four switches I am trying to install. Before, there were four regular switches which controlled:
Switch 1) Outside Lights (Only controlled with this switch)
Switch 2) Outside Lights (Only controlled with this switch)
Switch 3) Inside Lights (One other switch controlled)
Switch 4) Inside Lights (One other switch controlled)
I would like to install, in the order of the pictures below, a timed outside light in the first and second position, a dimmer for the third and a regular three way light for the forth.
I am having trouble figuring out where to wire everything from the new switches, especially the blue wires. Please help!
Thank you in advance!
mrmag is offline   Reply With Quote
Old 08-31-2013, 02:26 PM   #2
Licensed electrician
Rewards Points: 1,052
The blue on the one switch says it is the load going to the fixture. A hot wire would feed the switch.
Also SW1 does not have a white. That is a black that has been painted over. You can scratch the paint off with your nails to see the correct colors.
Old 08-31-2013, 02:37 PM   #3
Where does the ground connect to the first two switches? I do not see anything on the actual switch.
Old 08-31-2013, 08:55 PM   #4
Resi EC
Rewards Points: 252
The hot wire for SW1 appears to be white with black tape to re-identify it.
It could be a switch loop, with no neutral, so the timer (that needs a neutral) won't work.
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 08-31-2013, 11:24 PM   #5
Electrical Contractor
kbsparky's Avatar
There is a neutral present in the switch box.
The OP will need to add a pigtail from the white wires that are all wire-nutted together to make any timer work.
Edit to add: You may be correct, if that switch loop is on a different circuit than the rest of the switches there.....
-KB
Old 09-01-2013, 12:13 PM   #6
Update:
I wired the switch 1 by doing the following:
Black (Line) from Switch - Black (hot) in box
Blue (Load) from Switch - Wire marked as "Switch 1 White)
White (Neutral) from Switch - Wire-nutted with Whites in box
Turned on the juice and no power. In fact, the GFCI upstream tripped and will not reset.
What am I doing wrong?
Old 09-01-2013, 01:02 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm going to suggest this now...call an electrician before you make a small service call a really expensive one.
That GFI is not upstream if it is tripping. It is probably tripping because you used the neutral and shouldn't have...thus creating an imbalance the GFI is sensing on its load side.
weird wiring and wierd voltages on 3 dual switches... meweber1000 Electrical 5 12-18-2012 01:37 PM
Question on wiring two banks of lights from two switches dustycreek Electrical 3 09-09-2012 05:34 PM
Wiring fixtures when there are three way switches involved phospher Electrical 17 05-27-2009 10:56 PM
Wiring diagram for lights with two switches Ed M Electrical 7 08-10-2008 09:59 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
