Help With Wiring A Flourescent Fixture... - Electrical - DIY Chatroom Home Improvement Forum
Old 12-19-2009, 12:27 PM   #1
help with wiring a flourescent fixture...
I accidentally bought a fluorescent fixture which isn't outlet ready, it is ready to be wired into a series I guess. Could I take an extension cord, cut it, and wire it to the fixture and make it outlet ready? Is that possible?
Bades is offline   Reply With Quote
Old 12-19-2009, 02:03 PM   #2
Electrician
Rewards Points: 760
Yup that is possible, can't say for sure if it is code compliant or not. I would be comfortable putting a some SJOW and a plug end on it. This is not what the manufactuer intended so it may be wrong.
Can you not just hardwire the light.
darren is offline   Reply With Quote
Old 12-19-2009, 03:10 PM   #3
I wouldn't hard wire it for this application. I'm using it on an arcade cabinet to light up a plexiglass decal I have.
Old 12-19-2009, 03:50 PM   #4
Cool it worked.
Old 12-19-2009, 10:38 PM   #5
Rewards Points: 1,418
These 2 foot or 4 foot or 6 foot fluorescent fixtures that are outlet ready have:
1. A 3 wire cord and 3 prong plug for grounding,
2. A bushing or clamp that protects the cord from the sharp edges of the hole in the fixture the cord is threaded through,
3. A bushing or clamp (may be the same one as #2) that prevents a moderate tug on the cord from straining the wire nuts or other connections inside.
Help with wiring a new light fixture tinkin3 Electrical 10 09-09-2009 10:26 PM
Light fixture: Does hot&neutral designation matter, and possible wiring anomaly. Deck Electrical 8 08-26-2009 09:08 AM
Ceiling Fixture Wiring Issue trillen88 Electrical 4 04-13-2009 07:07 PM
Is it safe to plug in this flourescent fixture? doofalot Electrical 2 08-16-2008 02:27 PM
New Ceiling fixture Wiring Question rsteps Electrical 4 07-12-2007 08:51 AM
