Help With Wiring Fan Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-08-2013, 08:40 AM   #1
I am replacing a regular switch with a humidity sensor switch. The regular switch worked fine.
It has two black wires and a ground coming from it.
My new humidity sensor has more wires and I don't know which ones to connect them to.
Here is a video:
I the video, when I say "the light, however, does work"... the light I'm referring to is connected to the switch on the right.
I would just do a "trial and error" thing, but I'd rather not have any fire department activity or have a broken switch on my hands.
Thanks!
maczeemer is offline   Reply With Quote
Old 11-08-2013, 11:06 AM   #2
Rewards Points: 18
Take the white (neutral) wire from the new switch and wire nut it with the two white wires that are still tucked into the box.
daveb1 is offline   Reply With Quote
The Following User Says Thank You to daveb1 For This Useful Post:
maczeemer (11-08-2013)
Old 11-08-2013, 11:14 AM   #3
Worked perfect!
Old 11-08-2013, 11:14 AM   #4
Rewards Points: 334
dave has it right, take that white out & tie it too the others.if the two blacks just went to a single pole switch then you should be good. i belive the neutraul is for the pilot light to operate.
circuitman is offline   Reply With Quote
Help Wiring Dimmer Switch scubakathy84 Electrical 2 12-21-2011 11:26 PM
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Unusual three way switch wiring help r1racer Electrical 9 11-11-2010 09:49 PM
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
