Help Wiring A Dimmer - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 09:33 AM   #1
Rewards Points: 109
Help wiring a dimmer
Hi,
I am trying to replace two of my switches in the basement with a new Decora style switch and a dimmer. I disconnected one of the switches without marking anything, so that was probably my first mistake.
So what I have now is:
- Existing three way switch at the top of the stairs with a single 12/3 going to it.
- Another 12/3 where the old switch was and where I would like to add a dimmer.
- Based on what I have, I am assuming that I have it wired this way
Questions:
- The dimmer I am using is a Leviton ( http://www.leviton.com/OA_HTML/ibeCC...minisite=10025) and the three way instructions say
Connect wires per WIRING DIAGRAM as follows:
Screw wire nuts on clockwise making sure no bare
conductors show below the wire connectors. Secure each
connector with electrical tape.
• Green dimmer Ground lead to Green or bare copper wire
in wall box.
• Black dimmer lead to tagged Line (Hot) wall box wire
identified when removing old switch.
• Blue dimmer lead to Load wall box wire.
• Yellow dimmer lead to remaining wall box wire.
It also says
WARNINGS AND CAUTIONS:
• Use only one (1) dimmer per load. For remote operation, use Leviton Remote, Cat. No. TT00R-1.
Do not use a 3-way switch
And that's where I am lost
Help please!
BimmerRacer is offline   Reply With Quote
Old 01-09-2012, 09:49 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by BimmerRacer View Post
The dimmer ... instructions say
• Green dimmer Ground lead to Green or bare copper wire in wall box.
• Black dimmer lead to tagged Line (Hot) wall box wire identified when removing old switch.
It also says
This looks like a regular (NON 3 way) dimmer switch instruction...
that implies, but doesn't actually say, it wants a neutral wire as well.
It doesn't appear to have enough wires to work as a 3 way dimmer.
3-Way Dimmer Switches typically come with the following pre-wired leads:
Green wire - attach to the bonded ground wire(s) in the switch box.
Two Red wires - these attach to the "travelers" - the pair of wires attached to the two screws at one end of the regular 3-way-switch.
One Black wire -attach to the wire commonly found on the screw by itself on the regular 3-way switch, typically the Power or the Switch Leg leaving to the fixture(s).
hth
Old 01-09-2012, 10:04 AM   #3
Rewards Points: 109
The "optional" yellow wire is what's suppose to make it a 3 way, so there's a total of 4 wires, incl ground, coming out of the dimmer.
Old 01-09-2012, 10:16 AM   #4
Licensed Pro
That particular dimmer requires a matching remote as the second switch, not a standard 3 way switch. You will either have to replace the 3way switch with the required remote or replace the dimmer with a standard 3way dimmer.
The Following User Says Thank You to HouseHelper For This Useful Post:
frenchelectrican (01-10-2012)
Old 01-09-2012, 11:11 AM   #5
Rewards Points: 109
So assuming that I can find a remote switch at HD, how does the dimmer get wired?
Old 01-09-2012, 11:51 AM   #6
Licensed Pro
Just like the instructions say to do it.
Old 01-09-2012, 12:15 PM   #7
Rewards Points: 109
Err...sorry, I meant which one would be hot and which one is load?
Old 01-09-2012, 11:44 PM   #8
Rewards Points: 240
This sounds like it works the same way as the PCS and HAI dimmers I've used. The main unit gets both the line and the load connections. The remote gets a hot and a "signal" line that it uses to send signals back to the main unit. That's what the yellow lead on the dimmer you have is for. You can make this setup work, but you'll have to make changes in the connections in the fixture box.
If you want to use a standard 3-way switch in the circuit, you've got the wrong dimmer.
fa_f3_20 is offline   Reply With Quote
Old 01-10-2012, 12:10 AM   #9
" Euro " electrician
frenchelectrican's Avatar
I was reading it and as soon I did see the word " do not use the standard 3 way switch " I knew it right away that is what I called multi location dimmer switch so it will work with two or more dimmer in that fashion so you can turn it on or off at any spot plus can dim or brighten up at any location.
There is very sepecfic way to do this if you have switch loops that will get very tricky to address due the mulit location dimmers unit must have incomming hot source then outgoing hot source at the other switch location however you have to pay attetion to the conneciton colour format this is very important otherwise it will jamais (never) function at all.,,
I have done few of them also please make a note of connection at the luminarie location as well so you will know which colour you will dealt with it.
Merci,
Marc
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 04:24 PM
Help with 3 way dimmer wiring. boscru6469 Electrical 24 12-11-2010 09:40 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Dimmer switches brokenknees Electrical 9 11-29-2009 05:59 PM
Dimmer wiring in a box with 3 black and 3 white wires and a pink wire to boot! everender Electrical 9 02-15-2009 09:24 AM
