Help Wiring Detached Garage To Code - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2008, 07:00 PM   #1
Rewards Points: 274
help wiring detached garage to code
Should of asked this sooner as I about through (was using NEC 2002 but county uses 2005) but here goes: Wiring detached garage with one 20 amp circuit from main house breaker. One 12/2 w/ ground UF cable in 1" conduit buried 18" deep (I thought 6" was enough but inspector said 18") to disconnect mounted on exterior of garage. From there i am pulling two 12/2 cables: One for 5 outlets (first one GFCI) and one for 5 lights: 2 coach lights, 1 outside service door and 2 overhead flourescents (which are plugged into 2 additional outlets) I am "pigtailing" the 12/2 line side in the light switch box to have 2 seperate light switches. Also, do I need a 3' x 3' concrete stoop outside service door? Thanks in advance for any help.
ugabulldog is offline   Reply With Quote
Old 08-04-2008, 07:38 PM   #2
Rewards Points: 6,652
Personally, it would of been better to pull #6 or #8 to allow for 240vac service, and with that, you could go 60amp to allow for future needs. That is just my opinion. My garage had 12awg NM, and ended up pulling, and replacing with 10awg for a 30amp circuit to allow all 120vac for a 20amp for outlets, and 15amp for lighting.
Old 08-04-2008, 08:15 PM   #3
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
The electrical sounds ok. But GFCI protect those florescent light receptacle outlets also. Many inspectors will allow the garage door opener exception, but no other ceiling receptacles under the 2005.
I have no idea about the cement work.
John
jrclen is offline   Reply With Quote
Old 08-04-2008, 08:17 PM   #4
Rewards Points: 274
Greg, you are not the first to suggest that I add more power capability but I decided to go this route anyway.
I just read that cables running horizontally between studs need to be at least 8' if not covered by sheetrock..... looks like I will be re-pulling some anyway.
Old 08-04-2008, 08:29 PM   #5
jrclen's Avatar
Rewards Points: 514
Is that a local code?
John
Old 08-04-2008, 08:38 PM   #6
Rewards Points: 274
jr, here is a link where i read it: http://www.stpaul.gov/DocumentView.asp?DID=1404 page 2
I thought they pulled it from the NEC, maybe local, I hope? I do not live in St. Paul.
Old 08-05-2008, 07:39 AM   #7
The reason for being up in the Rafters, is so that people do not hang stuff off of them, and the wire actually has to be secured along the rafters, not just laying there.
Old 08-05-2008, 08:48 AM   #8
jrclen's Avatar
Rewards Points: 514
That is a local code. I suppose some people might use the romex to hold their tools or something. Give your local inspector a call to make sure. That is not in the NEC.
John
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
wiring detached garage ugabulldog Electrical 5 07-24-2008 04:13 PM
Wiring new detached garage/studio WShawn Electrical 4 07-21-2008 06:13 PM
Enhancing existing wiring to detached garage justinperkins Electrical 46 07-07-2008 07:29 PM
Grounding for detached all-metal garage geeswanie Electrical 3 07-03-2008 07:31 AM
