-   -   help wiring detached garage to code (http://www.diychatroom.com/f18/help-wiring-detached-garage-code-24746/)
ugabulldog 08-04-2008 07:00 PM
Should of asked this sooner as I about through (was using NEC 2002 but county uses 2005) but here goes: Wiring detached garage with one 20 amp circuit from main house breaker. One 12/2 w/ ground UF cable in 1" conduit buried 18" deep (I thought 6" was enough but inspector said 18") to disconnect mounted on exterior of garage. From there i am pulling two 12/2 cables: One for 5 outlets (first one GFCI) and one for 5 lights: 2 coach lights, 1 outside service door and 2 overhead flourescents (which are plugged into 2 additional outlets) I am "pigtailing" the 12/2 line side in the light switch box to have 2 seperate light switches. Also, do I need a 3' x 3' concrete stoop outside service door? Thanks in advance for any help.
gregzoll 08-04-2008 07:38 PM
Personally, it would of been better to pull #6 or #8 to allow for 240vac service, and with that, you could go 60amp to allow for future needs. That is just my opinion. My garage had 12awg NM, and ended up pulling, and replacing with 10awg for a 30amp circuit to allow all 120vac for a 20amp for outlets, and 15amp for lighting.
jrclen 08-04-2008 08:15 PM
The electrical sounds ok. But GFCI protect those florescent light receptacle outlets also. Many inspectors will allow the garage door opener exception, but no other ceiling receptacles under the 2005.
I have no idea about the cement work.
ugabulldog 08-04-2008 08:17 PM
Greg, you are not the first to suggest that I add more power capability but I decided to go this route anyway.
I just read that cables running horizontally between studs need to be at least 8' if not covered by sheetrock..... looks like I will be re-pulling some anyway.
jrclen 08-04-2008 08:29 PM
Is that a local code?
ugabulldog 08-04-2008 08:38 PM
jr, here is a link where i read it: http://www.stpaul.gov/DocumentView.asp?DID=1404 page 2
I thought they pulled it from the NEC, maybe local, I hope? I do not live in St. Paul.
gregzoll 08-05-2008 07:39 AM
The reason for being up in the Rafters, is so that people do not hang stuff off of them, and the wire actually has to be secured along the rafters, not just laying there.
jrclen 08-05-2008 08:48 AM
That is a local code. I suppose some people might use the romex to hold their tools or something. Give your local inspector a call to make sure. That is not in the NEC.
