Help - Wiring A Chandelier - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2012, 04:24 PM   #1
Help - wiring a chandelier
Hi,
I own a prop studio in Monterey, CA and I am building what is essentially a chandelier. A pile of skulls with 5 candles on 5 of the skulls in the pile. So I need to wire 5 - 40 w flicker bulbs with the small chandelier bases to one power cord.
I need to know what wire I should use, connectors, cords. I assume I can just wire all 5 lights to a cut off extension cord and use twist caps and electrical tape to make sure things stay put. I want to make sure things don't catch fire, kill people, or simply fail to work.
This is for indoor use.
Luke
Sparks-Magee is offline   Reply With Quote
Old 11-20-2012, 04:27 PM   #2
Rewards Points: 6,652
Wago conectors, but you really would wire it in parallel, so if one bulb goes out, the rest stay lit. you can buy lamp cord, since an wxtension cord is not rated for that use.
Old 11-20-2012, 04:32 PM   #3
Wow thanks for the quick reply.
Can you give me a shopping list? I know that is asking a bit of you but I don't know what connectors to get what size wire and I don't know what wire in parallel means
Old 11-20-2012, 04:36 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Seems to me that this is a for profit business. Being as such, do your own homework.
Old 11-20-2012, 05:38 PM   #5
Civil Engineer
Rewards Points: 4,766
If you are building this fixture for your prop studio, you really should carefully check first to see if using this home made light is going to void your business insurance against fire. The reason is that there is no way you are going to get an Underwriter Laboratory approval for a home made fixture, so you will be knowingly installing an unapproved fixture. While this might not be a problem in your home, in the sense that your homeowner's insurance might pay off if you burned your house down because of faulty wiring, the same might not be true in a business environment.
Old 11-20-2012, 05:41 PM   #6
Good point. I have to solve that one first. Thanks for the meaningful reply.
two dimmers, 1 for spots 1 for chandelier help Nessa Electrical 9 01-31-2012 11:34 PM
Wiring issues installing chandelier seminole1 Electrical 0 04-03-2011 04:01 PM
Replacing Chandelier Green Grounding Wire? wyjadka Electrical 4 03-24-2011 06:22 PM
Ceiling Fan Wiring Problem kayl Electrical 7 02-23-2011 06:19 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
