Help Wiring A Ceiling Fan With 3-way Switch And Dimmer - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 03:04 PM   #1
Help wiring a ceiling fan with 3-way switch and dimmer
I'm a new poster, but I have been using this site for a while to answer a lot of questions. I couldn't find anything that answers this specific question.
I have the setup that I drew below, and I'm not sure what connections that I need to make to complete the wiring. Thanks in advance for the help!
csbaker80 is offline   Reply With Quote
Old 06-15-2012, 03:56 PM   #2
Licensed electrician
Rewards Points: 1,226
Are you running new cables or dealing with old wiring? What is the order of the switches and fan/light compared to the power source?
csbaker80 (06-15-2012)
Old 06-15-2012, 04:51 PM   #3
Rewards Points: 1,440
What do you want the switches to do. For example do you want the 3 way action to override the dimmer? Do you want 3 way for the fan and the light to be dimmed and controlled from one location only?
The Following User Says Thank You to AllanJ For This Useful Post:
Old 06-15-2012, 04:58 PM   #4
Jim, thanks for the reply. I actually figured out what to do while I was waiting for a reply. I ran a separate 14/2 directly from the junction box to the fan switch and a 14/2 between the dimmer switch and the fan switch (they are separated by a stud). I connected the whites together and connected a black to each side of the switch. I then connected the black to the red that is running up to the ceiling fan and the white to the whites from the other switches.
I guess another option would have been to run a 14/4 from the first switch to the second set of switches.
Does this sound correct? It works, but I want to be sure that it was done correctly. I can draw out what I did if that will help.
To answer your question - the original single pole switch was old wiring, but now everything in this circuit is new wiring.
This was a serious all day project working with thick plaster walls, but I think that I finally got it done.
Old 06-15-2012, 04:59 PM   #5
Allan, the light is controlled by the dimmer and the 3-way. The fan is single pole.
Please let me know if what I did sounds correct.
Replacing a dimmer switch with a regular switch for a ceiling fan RP DeMars Electrical 0 04-18-2012 04:25 PM
wiring a digital dimmer switch albertlayden Electrical 8 01-27-2012 07:33 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 08:40 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
