Help Wiring Blower Fan - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 09-25-2013, 04:36 AM   #46
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by Philly Master View Post
I gove you the right stuff already ..re read ..LOL
post # 10
http://www.gbindustrialdirect.com/fa...FZSd4Aod-CYAXg
Originally Posted by Lupus71 View Post
I saw the fan switch but was worried about it being 5 amps and the motor is 5.4. If you think it's good though I'm all for it! Thanks for the help!
If you are talking to me ... ...LOL
its a 10 amp switch ..ie
"Three-speed wall mounted switch for positive control of 3-speed fan motors. Switches have auxiliary lead for line voltage thermostat control. Rating: 10A - 125 VAC., 5A - 277 VAC."
10 amps at 125 volt
5a is at 277 volts
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 09-25-2013, 05:25 AM   #47
Rewards Points: 516
this may help ...LOL
Help wiring blower fan
Originally Posted by biggles View Post
for the speed selecting...that RED wire is the one that has to be switched to the speed colors....so why not just install 3 toggle switches and select the one you want to run ..but keep in mind never put 2 speeds ON the one motor at the same time.... basically like a ceiling fan speed selector but for a larger motor as you have
what ?????
Old 09-25-2013, 07:55 AM   #48
macon, ga bibb county
Rewards Points: 150
Philly, it's wired 240v. I was alittle confused myself by the red wire thing. The red wire is the lo speed. Are you just saying hook it and the other speed wire to their own switches?
Lupus71 is offline   Reply With Quote
Old 09-25-2013, 08:48 AM   #49
Rewards Points: 150
Well found a 10 amp toggle that will work. Thanks for all the help and sorry to drag a switch question out so long= 49 posts!!!
Old 09-25-2013, 12:48 PM   #50
Rewards Points: 150
Umm I'm back.... Anybody know how to wire this dpdt toggle switch to romex?
Old 09-25-2013, 01:46 PM   #51
Rewards Points: 150
I jumped the yellow com from the motor and its working. Hope that its right.
Old 09-25-2013, 02:18 PM   #52
Rewards Points: 360
belive the middle is common,so there is where you would bring in your 240 ,then the outside would be your two speed selections.just would have too jumper one screw each on the outside for your common. i belive the three way switch would have handled this just as easily.
circuitman is online now   Reply With Quote
The Following User Says Thank You to circuitman For This Useful Post:
wirenut1110 (09-25-2013)
wiring 3 wire blower motor to pop up vent frustratedbill Electrical 1 12-03-2012 02:22 PM
Montgomery wards 700 blower wiring Thathayes HVAC 4 11-13-2012 09:21 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 08:06 AM
Need help wiring a.c.smith blower moter STEVEEBY HVAC 8 07-02-2011 09:26 AM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
