Help Wiring Blower Fan - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-22-2013, 09:35 AM   #16
PoleCat's Avatar
Rewards Points: 1,652
I would just buy a three position fan switch to avoid confusion. As a mater of practice I always use a double pole switch with a 240V device. You don't have to but cutting both legs with one throw brings me a modicum of comfort.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Philly Master (09-22-2013)
Old 09-22-2013, 09:52 AM   #17
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by Lupus71 View Post
e now Philly, but that's why I'm on here asking. Never messed with 240v stuff. I guess the main question now is, is the yellow common from the motor hooked to one of the hots with a disconnect switch, and like wirenut said the other hot to my bottom switch. How would I hook up the different speeds? Thanks for putting up with me!
Since i make my living as an Electrical contractor i could never tell you to do it the way that is being discussed ... on many levels ..
so ... the switch i referenced earlier .... http://www.gbindustrialdirect.com/fa...FZSd4Aod-CYAXg
1) is RATED for a motor
2) will give you all 3 fan speeds
and as pole cat suggested you need a way to DISCONNECT the equipment from ALL the electric .. the simple way would be either a 2 pole switch or your basic 60 amp disconnect like for an outside A/C unit ( about $ 9.00 )
http://www.homedepot.com/p/GE-60-Amp...5#.Uj8DQoU4m1A
keeping the switch and the disconnect seperate
added***
i would also recommend using MC wire from both the disconnect and switch to the motor
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 09-22-2013, 10:02 AM   #18
Rewards Points: 516
this may help ...LOL
Old 09-22-2013, 10:09 AM   #19
Rewards Points: 516
at the top of your diagram there is L1 and L2 ( L= line or HOTs )
you'll need a 2 pole breaker to come off of in your panel ...
that wiring goes to the "disconnect" as i linked you ..
from the disconnect to the L1 and L2 at the motor ( yellow and black ) ... also read NOTE #1 ...
Old 09-22-2013, 10:16 AM   #20
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Originally Posted by wirenut1110 View Post
I would get a double gang box, put a double pole switch in it, run your feed through that then, wire as above. Your 3-way switch will have 3 screws. 1 Black and 2 brass. Come off of your DP switch to the black screw, and hook motor black to one brass screw and motor red to the other bras screw. Motor common(yellow) will come off the other side of your DP switch.
I'm not sure why there is an issue with this suggestion?
wirenut1110 is offline   Reply With Quote
Old 09-22-2013, 10:25 AM   #21
Rewards Points: 516
on the surface it is home-ownerie at best ..LOL
is the switch rated for motors ??
does it do all three speeds ??
how do you turn it off ...
Old 09-22-2013, 10:31 AM   #22
Rewards Points: 510
For a small blower motor that only pulls 5 amps? LOL I see single pole or double pole switches used for furnace and dishwasher disconnects all the time. Hell, a damn vacuum cleaner/washing machine pulls more than twice this motor does, are all the receptacles/switches in a house motor rated Quite a bit overkill to put a 60 amp pull out disconnect to use as an on/off switch. At least his switch is a 15 amp switch vs the 10 amp one you suggested. LOL
Old 09-22-2013, 10:54 AM   #23
Rewards Points: 516
yea $ 9.00 is over kill ... for a disconnect .... LMAO ...
is simple and cheap ..less labor to install ...less parts to buy .
the way i spec'd the job and the parts .. the disconnect is NOT an on/off switch ... it is a DISCONNECT .. the Fan control turns the fan on and off ..that was spec'd, plus gives you ALL 3 speeds ...
there is a difference when turning a garbage disposal on and off then doing a 3 speed motor/fan control ...
do u use that set up for ceiling fans too ???
Old 09-22-2013, 05:45 PM   #24
macon, ga bibb county
Rewards Points: 150
Hey guys just wired it up to test it with just the hi speed hooked up and when I flipped the switch it tripped the main breaker. I used a 20 amp dpst, with 12-2 grounded to the metal box, I hooked the white and black hot line to the left side and hooked the yellow common and the black hi speed to the right. Flipped it and blew instantly.
Lupus71 is offline   Reply With Quote
Old 09-22-2013, 05:52 PM   #25
Rewards Points: 366
some double pole switches feed line in on top & load out the bottom two. some or different. if the switch was in a package, there should be a wiring diagram on it.different companies making'em different ways.
circuitman is offline   Reply With Quote
The Following User Says Thank You to circuitman For This Useful Post:
Philly Master (09-23-2013)
Old 09-22-2013, 05:54 PM   #26
Rewards Points: 366
i belive my last post will be correct feed the black & white in the top & the load out the bottom two screws.
Old 09-22-2013, 05:58 PM   #27
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Attachment 76150
Attachment 76151
You have absolutely no idea what you are doing.
Did you read the wiring diagram on the switch? Every 2P switch I've seen line was lower, load was upper.
Your other problem is that a single 12/2 from the switch to the motor will not allow you to use more than one speed.
The Following User Says Thank You to k_buz For This Useful Post:
Old 09-22-2013, 06:01 PM   #28
dmxtothemax's Avatar
Rewards Points: 5,504
I don't see why there is a problem with his switch?
If the switch is only rated for 120v ?
Then using it on 240v could be problem !
Check the ratings for the switch ?
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Old 09-22-2013, 06:04 PM   #29
Rewards Points: 510
The switch won't see 240 volts. It's only switching one leg.
Old 09-22-2013, 06:13 PM   #30
Rewards Points: 510
Lupus, You need to put your wires under the plate then tighten the screws, not wrap the wires around the screw. Also, are you sure this is a double pole switch and not a 4-way? It should have a label on the back that says double pole.
wiring 3 wire blower motor to pop up vent frustratedbill Electrical 1 12-03-2012 02:22 PM
Montgomery wards 700 blower wiring Thathayes HVAC 4 11-13-2012 09:21 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 08:06 AM
Need help wiring a.c.smith blower moter STEVEEBY HVAC 8 07-02-2011 09:26 AM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
