Help Wiring Blower Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2013, 12:16 PM   #1
macon, ga bibb county
Rewards Points: 150
Help wiring blower fan
I'm making an air cleaner for my shop and need to wire up my blower to 12-2 romex. The fan has red-lo,blue-med, black- hi, yellow-com, yellow green- ground and two browns going to capacitor. I tried to hook it up red to black powe on romex, yellow to neutral on romex and romex ground to the fan body. It twitched then stopped and flipped the breaker. Any help?
Lupus71 is offline   Reply With Quote
Old 09-21-2013, 12:31 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Do you have the right voltage? What size breaker and what's the motor amperage?
wirenut1110 is offline   Reply With Quote
Old 09-21-2013, 12:39 PM   #3
Rewards Points: 150
Think I found the prob. I was using a arc fault breaker. Went to another one and now it works. Can I wire this to a switch to use the 3 different speeds?
Old 09-21-2013, 12:48 PM   #4
Rewards Points: 150
I'm not sure of the amps and honestly not the voltage either. I assumed it was 120v being its only 3 wires
Old 09-21-2013, 01:46 PM   #5
Rewards Points: 388
the data should be on the motor nameplate, not knowing the voltage can let out the magic smoke!
circuitman is offline   Reply With Quote
Old 09-21-2013, 02:13 PM   #6
Rewards Points: 150
It doesn't say. Is there any other way to tell?
Old 09-21-2013, 03:30 PM   #7
Philly Master's Avatar
Rewards Points: 516
its under the bracket ...LOL
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 09-21-2013, 05:42 PM   #8
Rewards Points: 150
Ok found it. It's a 3/4 hp 208-230v ,5.4 amps. So how would I go about wiring that so I could at least have the choice of a hi and low. I bought a 3 way dual button switch . Can I use that some how?
Old 09-21-2013, 05:48 PM   #9
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Your threads make me shake my head....
The Following User Says Thank You to k_buz For This Useful Post:
Philly Master (09-21-2013)
Old 09-21-2013, 06:05 PM   #10
Rewards Points: 516
http://www.gbindustrialdirect.com/fa...FZSd4Aod-CYAXg
Old 09-21-2013, 06:40 PM   #11
Rewards Points: 150
Why is that kbuz?!?! Because I took a pic of the wiring dia.? If so its just that its really confusing. I seem to upset alot of people with my posts. Maybe I will figure it out one day. Thanks for the help anyway.
Old 09-22-2013, 04:34 AM   #12
Rewards Points: 516
i think Mr. Buz was shaking his head because u figured out that it was a 208/240 volt motor but you are holding a clearly marked 120 volt switch asking if it will work ...
Old 09-22-2013, 06:37 AM   #13
Rewards Points: 510
I don't see why there is a problem with his switch?
One hot leg would go straight to the motor common and then the other hot leg would go to the common on the switch and hi and lo would connect to the traveler screws.
This wouldn't be a disconnecting means but it would allow for speed change.
Old 09-22-2013, 09:11 AM   #14
Rewards Points: 150
e now Philly, but that's why I'm on here asking. Never messed with 240v stuff. I guess the main question now is, is the yellow common from the motor hooked to one of the hots with a disconnect switch, and like wirenut said the other hot to my bottom switch. How would I hook up the different speeds? Thanks for putting up with me!
Old 09-22-2013, 09:28 AM   #15
Rewards Points: 510
I would get a double gang box, put a double pole switch in it, run your feed through that then, wire as above. Your 3-way switch will have 3 screws. 1 Black and 2 brass. Come off of your DP switch to the black screw, and hook motor black to one brass screw and motor red to the other bras screw. Motor common(yellow) will come off the other side of your DP switch.
wiring 3 wire blower motor to pop up vent frustratedbill Electrical 1 12-03-2012 02:22 PM
Montgomery wards 700 blower wiring Thathayes HVAC 4 11-13-2012 09:21 PM
Odd Fireplace Outlet Behavior permagrin Electrical 2 12-17-2011 08:06 AM
Need help wiring a.c.smith blower moter STEVEEBY HVAC 8 07-02-2011 09:26 AM
AC blower short cycling-works on heat though Steve60007 HVAC 14 06-22-2009 04:00 PM
