Help Wiring Bathroom Fan. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2009, 10:16 PM   #1
Help wiring bathroom fan.
Trying to wire a new fan in my bathroom but not sure how to wire it. I have old conduit wiring in my house with only black and white wires. However the fan has 2 white, one black, one blue and one green wire. So how should I wire the fan. I have attached the installationhttp://www.homedepot.com/catalog/pdfImages/9c/9c7d2e4c-08c4-4f00-b6e1-6757a06da469.pdf
instructions which include a wiring diagram if that can help.
This is my first post and thanks for your help.
Elephantman is offline   Reply With Quote
Old 03-15-2009, 10:23 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
If you want the light and fan to come on at the same time, wire the black and blue together from the switch. Wire the whites together.
If you want the light and fan to be operated separately, then you will need to add another wire and another switch.
Old 03-16-2009, 04:19 AM   #3
Thank you for the answer jbfan. What about the green ground should I just cap it off?
Old 03-16-2009, 06:39 AM   #4
Vann
If there are green or bare copper wires in the box, connect to the green fan wire to them(or it). Or if the juntion box is metal connect to box with a screw or special clip.
vann is offline   Reply With Quote
Old 03-16-2009, 08:10 AM   #5
Rewards Points: 77
I installed a bathroom exhaust fan recently, my home is older with only hot & neutral in BX conduit. I did what vann suggested. Clamp your BX onto junction box, make connections inside, then run ground from fan to the jb and secure it with a ground screw or clip. I srewed JB to 2x4 in attic above bathroom.
dbldee20 is offline   Reply With Quote
Wiring Problem in Bathroom notasparky Electrical 7 10-27-2008 06:34 PM
Bathroom Fan/Heater unit incompatible with electric wiring? bathroom nightmare Electrical 4 02-09-2008 03:41 PM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 06:25 PM
Help with bathroom wiring - URGENTLY NEEDED cfonseca Electrical 4 02-16-2007 01:42 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
